Skandix order to USA June 2025
- Been thanked: 4068 times
If you need parts from Skandix Im ordering some engine stuff and you can ride on my 100 EU shipping from GER to USA, I can ship to you from NY using USPS at the usual flat rate box charges. Lets use this thread for the list, and PM for payment info
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Well being the big spender that I am, I'll take 2 of the valve spring retainer washers. Not that I'd ever lose one.
1999 V70 GLT
1999 V70 GLT
- Sveedy
And the lost washer has been found ! Amazing what distance a little piece of metal can fly.
So Thanks everyone for your help. At least I learned about the change in valve stems in '99.
1999 V70 GLT
1999 V70 GLT
Not yet. Added
order submitted
Pm me your address so I can send these to you!Ttrojan wrote: 28 Jan 2025, 15:00 Have you ordered yet? In need of this #1268660 fork guide rail for my 740.. might as well get 2each
And this #1268661 fork guide rail front 2each
Next Skandix order, June 2025
Anyone want brake rebuild kits?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Did we ever find a source for the eccentric bolts on the rear end of the '99 V70 XC AWD? I'm guessing someone makes them for other purposes - trick is tracking them down.
- Has thanked: 987 times
- Been thanked: 1075 times
Mercedes also uses eccentric suspension bolts. What are the chances they are the same? Anyone have some dimensions?wizechatmgr wrote: 08 Apr 2025, 07:46 Did we ever find a source for the eccentric bolts on the rear end of the '99 V70 XC AWD? I'm guessing someone makes them for other purposes - trick is tracking them down.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Thinking out loud - could a thick washer with an eccentric hole be welded to the appropriate bolt head?
- 65 Replies
- 15974 Views
- 1846 Views
Last post by IslandV70
- 2368 Views
Last post by MoVolvos
- 1198 Views
Last post by sev65
- 395 Views
Last post by MotorTheresa
