Dolby Pro-Logic; only central loudspeaker working Topic is solved
Radler
Year and Model: V70 1999
Has thanked: 26 times
Been thanked: 4 times
Post by Radler »
After checking for continuity on the cable loom and testing with a spare loudspeaker, I determined that the processor was to blame. Sadly I could not find a second hand processor for this system, so I decided to keep it simple and install a basic radio. Today I installed it on the car and finally I have sound in all loudspeakers; that is, except for the one on the dash, although I may bridge it to the original loom. I'll keep an eye in case a processor appears at a fair price, but it's not something that'll keep me from sleeping.
Thank you all for your help!
In case anyone was wondering, this is what the Dolby processor looks like inside:
Been thanked: 4067 times
Wow! The 1970s called and wants their circuit board back!
Radler
Post by Radler »
There are two boards; upon visual inspection I did not see any cracked solderings or burnt components, other than a weirdly-soldered ground terminal. Electronics are really not my thing so I can't say much more, I guess it could be repaired by replacing a couple of capacitors.
Has thanked: 2200 times
Been thanked: 1852 times
Unfortunately I don't have a spare. I'll check with my friend who pulled one from a V70R. He has a 850, so no center dash speaker, but although you can still use it it may not be worth it. Shipping will be the kicker, but if it comes available I'll let you know.
Nikolaech
Year and Model: Volvo 850 93
Has thanked: 15 times
Been thanked: 16 times
Post by Nikolaech »
Radler wrote: 08 Apr 2025, 05:52 After checking for continuity on the cable loom and testing with a spare loudspeaker, I determined that the processor was to blame. Sadly I could not find a second hand processor for this system, so I decided to keep it simple and install a basic radio. Today I installed it on the car and finally I have sound in all loudspeakers; that is, except for the one on the dash, although I may bridge it to the original loom.
Radio + amplifier work without processor.
Disconnect processor from radio and check.
Radler
Post by Radler »
Nikolaech wrote: 08 Apr 2025, 08:48Radio + amplifier work without processor.
Yesterday I tried my 2 Dolby head units (SC-900 & SC-901) with both amps and I can confirm that the system does not work without the processor, at least not in my case. In fact, not even the central loudspeaker: without the processor I can not even change the "mode" (normal, 3CH & Pro) in the head unit.
Nikolaech
Post by Nikolaech »
You have +12V power - OK
Speakers - OK
Processor-OK
Connection - sound blocking? (Tel. Mute)
if connected, disconnect and insulate this wire.
Standard connection from the manufacturer.
The color of the wires may vary.
Check.
Сonnection_Volvo SC9xx.JPG (35.11 KiB) Viewed 205 times
