tfo
Year and Model: 2007 XC70
Been thanked: 5 times
Post by tfo »
went on Digikey and bought some components today: replacement Thermister which is the CCM cabin air temp. sensor, and a bunch of LEDs to test out on the DIM, since mine were scraped off by someone before I bought the car. Testing clear vs. diffused red and orange (not amber) LED chips to see which one fits in best with the other OEM chips. should ship in 4 days or so.
i'm going to look closely at the neo-wedge filament bulbs with the blue filter in the CCM and key ringlight and also test out some replacements as well, but so far Digikey only has Clear or White filtered neo-wedges. gotta look elsewhere. they come in three different colors on my XC; white, grey, and black. i'm wondering what the difference is, if it even exists. i'll find out when I get the CCM out again to replace the thermister.
she/her
the sea of estrogen in question
PYXIE: 2007 XC70 ~172k mi.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
I always just replaced the neo-wedge bulbs with incandescent and transferred the old "sock" off the old onto the new.
Sorry noticed it's DIM lights you're replacing not the CCM ones. I shouldn't browse MVS at work.
04s60 2.4
04xc70 2.5t
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Working on VAG group cars gives me a ptsd shudder.
br0dy519
Post by br0dy519 »
BlackBart wrote: 08 Apr 2025, 09:57 Working on VAG group cars gives me a ptsd shudder.
are they that bad? I had an opportunity to look at an allroad audi that looked really nice. only chronic issue I saw with this group of vehicles is that the intake valves get horrible carbon buildup and require a walnut blast every 50k miles which seemed like a horrible way to spend $1000 every 2 years.
04s60 2.4
04xc70 2.5t
BlackBart
Post by BlackBart »
The first gen Allroad? They were NOTORIOUS for lack of reliability, one of the worst. As well as the Toureg.
The current gen Allroad seems to have overcome that reputation, totally new car, based on the A4 platform?...yes, A4.
Both Allroads are great looking, and I lusted after them, but the more I read, it was RUN AWAY! The 2nd gen used cheap with good records...? Maybe.
I had a 2001 A4 wagon 1.8T. Blew up the engine at 130k after diligent maintenance and full of fresh oil. Spun the rod bearings on the freeway. Apparently the original owner had coked up the oil passages because:
A - long service intervals by VW
B - the pan only held 3 1/2 qts of oil when full
C - there was way too much heat in the overcrowded engine compartment.
br0dy519
Post by br0dy519 »
It was a 2017. And yes my mechanic mentioned something about low oil volumes not helping.
04s60 2.4
04xc70 2.5t
Been thanked: 4069 times
I had to drop an oil pump into my 1.8T in ManBeetle due to wear , at 50k. Pretty easy job, $100 part.
Thst took me to synthetic oil for all my cars. Quite some years ago? 2016 according to Photos
18 year old Artemis supported me my watching the couch
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 09 Apr 2025, 02:28 I had to drop an oil pump into my 1.8T in ManBeetle due to wear , at 50k. Pretty easy job, $100 part.
For comparison: dealer Castrol every 10k for the first 7 years, then Amsoil Signature and Red Line every 5k for another 7-8 years.
Pretty much Castrol can't be undone w/o hot tanking the engine.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Today I tried to finally install my "new" ETM that is the blue box contactless version. Sadly, when connected to the engine(the body itself) the throttle oscillates like crazy and I get an ECM-91A7 code.
When not connected to the engine chassis, it seems to work fine when pressing the accelerator in key in pos II.
It's possible it's a software issue, but the issue seems to be similar to which may indicate a physical problem. And indeed unlike my original ETM, this one doesn't move as freely by hand, it feels like it's catching on something :/
If it is faulty, this means I was scammed and all my efforts unbricking it before were essentially all leading up to a dead end.
And I may need to do what this guy has done viewtopic.php?t=106311
vtl
Post by vtl »
Fuel pump fiasco. This is what was taken out:
This is what I've got:
Two motors in old pump vs one in new.
