Replaced front O2, immediate misfires, high trim. Diagnostic help? Topic is solved
Has thanked: 1611 times
Been thanked: 4071 times
Take the snorkel off the MAF and put a glove over it, keep. smoke away from the MAF.
leapdragon
Year and Model: 2007 XC70
Has thanked: 12 times
Been thanked: 31 times
Post by leapdragon »
So, smoke tested. Big leak in exactly the pipe suspected, all the way around the back where it's hard to feel/see. I guess I must have applied some pressure while I was in there in a way that caused it to crack. :-/
Also, leaking seals around the injectors, which is disappointing because I replaced those last time I cleaned them, but apparently the replacements left something to be desired.
Replacement parts on the way. Thanks everyone!
Vova585
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
Congratulations. Now you have another tool to play with in the future. BTW, which one you ended buying and would you recommend it 🤔
leapdragon wrote: 08 Apr 2025, 20:29 So, smoke tested. Big leak in exactly the pipe suspected, all the way around the back where it's hard to feel/see. I guess I must have applied some pressure while I was in there in a way that caused it to crack. :-/
Was the leak in the big snorkel pipe? Unlike bmw, the Volvo ones don’t seem to fail often
leapdragon
@abscate It was, there was a subtle split way back around the rear on the bottom just before the clamp. I got the sense that it was even been on there slightly crooked causing it to fail, hard to see, a certain amount of all of this was done by feel. *shrug*
New one is in place now, and the fuel trims are back in range at idle at about +6, and now I know there are smaller leaks around the injectors (still waiting on o-rings to come in for those).
@vova bought this one as recommended by vtl I believe: https://www.amazon.com/AutoLine-Pro-Aut ... 07JVT1NG2/
Re: do I recommend it, I honestly have no basis for comparison. I've never used another, but this one seems to have done the job without too much drama or being too difficult to figure out. :-D
The new drama is that I've noticed some oil drippage and I think it's coming from the breather box. :-/ So I'll have to take a Saturday and dismantle all of that sometime soon. I did the last PCV job on it but it's about 50k miles ago now, something must have broken loose. Always another job to do...
