'98 S70 T5 Won't idle, big delay in throttle response
rudsaki
Year and Model: 1998 S70 T5
Has thanked: 29 times
Been thanked: 16 times
Post by rudsaki »
Rear exhaust seal completely blown out, so performed that fix, PCV service(including cleaning gunk when I saw it) and new vacuum lines to turbo.
Post start it went to ~1500 rpm then dies. Try again same thing. Try to keep it alive with throttle, but barely responds to input. Noticed I did not put the fresh air intake snorkel on. Fixed that and gave the MAF some shots of throttle body cleaner. It did make a better try at idling, now giving me 5 seconds of chugging. Throttle the same. I doubled checked my turbo routing. I did not completely un-hook my intake manifold, just flopping it over and back many times.
New to me car that ran very well, except for dumping out a quart of oil!
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
daninater
Year and Model: 2003 XC70
Has thanked: 2 times
Been thanked: 3 times
Post by daninater »
Check for vacuum leaks below the manifold, on the manifold and turbo, on the pcv connections to the box.
Been thanked: 4068 times
You need to check the entire induction path for splits, cracks, loose clamps
On a turbo car, that’s 10 clamps and hoses, not counting PCV!
rudsaki
Post by rudsaki »
Yah try to be methodical in re-assembly, but it's a lot and connectors also. Hopefully did not break any wires digging and flopping stuff around
Previous Volvos
rudsaki
Post by rudsaki »
was able to use a free OBD scanner software and got
P0102: Mass or Volume Air Flow Sensor "A" Circuit Low
Because of oetiker clamp the air box lid was still attached and I moved it a lot doing the job. Maybe damaged it or is this still a sign of air leak?
Previous Volvos
rudsaki
Post by rudsaki »
Tried junkyard MAF, same result. Pulled MAF connection so it would barely idle then sprayed carb cleaner looking for vacuum leak. Two fuel injectors gave the biggest response. Replaced all o-rings and it ran 10% better. Spraying top edge of intake manifold also got a response, but all bolts tight.
This short video you can hear one of the backfires in the intake.
20250412_172330~2.mp4
(5.67 MiB) Downloaded 40 times
Previous Volvos
rudsaki
Post by rudsaki »
To complete the loop, my main problem was putting the PCV clip on the inside out the intake manifold like this guy in the UK.
https://www.volvoforums.org.uk/forum/te ... -after-pcv
Putting it back on the outside did the trick confirmed by carb cleaner spray test, perfect idle and throttle response. Other smaller leaks were the trashing 2 injector O-rings and loose oetiker clamps on vacuum tree big hose.
Now I can move on to making it pretty!
Thanks for the suggestions,
Rod
Previous Volvos
Ah yes, putting the holder on before the manifold.
A very good friend of mine did that once , years ago.
