How to reset the LTFT
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
solo99
Year and Model: v70 2012
Post by solo99 »
Hi,
I had a leak on the intercooler hose and fixed this. After 500 miles, the LTFT is more stable but still at 12% - 15%. I did a smoke test again, but no leaks.
I was thinking the LTFT has to be reset, since the leak has been there for a long time. The LTFT does seems to be 'stuck'. I checked this article: viewtopic.php?t=21123
So I disconnected the battery for 3 hours, pushed brake paddel etc. to discharge any condensators, but it did not work. I had to relearn the windows and the display clock, but the LTFT has not been reset.
I disconnected the MAF sensor and restarted and removed the DTC codes, but no effect.
V70 - 2012 - 1.6 petrol DrivE ford engine with startstop. BTW, I did not disconnect the small support battery since is it so far away.
Should I remove the ECU fuse? Any possible negative side effects if I do this?
Is there no simple OBD app that can do this reset for me?
solo99
Post by solo99 »
I was afraid there would be no answers. It seems to be a very difficult thing just to reset the fuel mapping. At least, I think I searched the whole internet for it. Since I came across the topic on this website about how highly important it is to reset the LTFT after a fix, I gave it a go. But I understand this is not a common question many people have experience with.
Has thanked: 1506 times
Been thanked: 3822 times
The LTFT is set by integrating the STFT which resets when you disconnect the battery. If your reader doesn’t show Stft at 0 after a battery disconnect, it’s a reader fault
solo99
Post by solo99 »
Are you sure? I thought the LTFT is a based on the STFT values over a longer period. If I disconnect the battery and the LTFT is still the same after reconnecting, then I must assume it was not reset at all. If it was, the LTFT would start at 0 and if there is still a problem, it would climb back to it's previous values because the STFT would correct instantly and heavy.
solo99
Post by solo99 »
I pulled the ECM fuse (nr 36). At least I now know the LTFT is carved in stone :). Put the fuse back in after 20 min, no effect. Pulled the fuse again, 1 hour later in contact push brakes etc, wait for another 2 hours. Put the fuse back in, checked the LTFT, still the same. I give up, there is no way to reset it.
