99' S70, 5-speed, Immobilizer Problem. End of the road for Matilda?
Has thanked: 2205 times
Been thanked: 1852 times
Wurth also makes a really good product, but whilst they let me make an account with them, as a non-industrial user they won't sell it to me in Canada. Fortunately I have a buddy in the automotive trade where they can order it. That is what our local dealer used on my P80 TCU/ECU.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
abscate wrote: 21 Mar 2025, 00:37 Ok, here are the two codes we unload from Mathilda, I want o dig I and understand if these are ECM faults or DIM faults
Egyptians in antiquity considered cats to be Deities. Cats have not forgotten this.
Been thanked: 4069 times
We have our next step in mind
Pull Mathilde ECu and try it in a known good DENSO 99 s70, see if we can talk to it through a good CDM and wiring
That should work. My car was not happy about it, but that was because I used a 4 speed auto trans CEM on a 5 speed auto. It did however start and run but threw codes. With a similar trans it should work and drive.
Dirk, from another thread
viewtopic.php?p=649708#p649708
Can you get Mrs Dirk to twist the key while you see if the main engine relay clicks ? Need good battery of course
That relay is closed by grounding at pin b38 on the ECM so thst will tell us if we have any ECM activity or if it’s dead.
It’s one of the three square relays in this picture, the rectangular one is the AC relay
I think it’s the J marked relay
Nope, it’s this relay…
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Thanks, Steve
I actually found that out when I looked at it. Got a good audible click on that relay, so that's probably good news.
Also, I took the ECU out to clean the contacts with DeoxIT, and I messed up royally. When we were doing the continuity test I used a tiny pin in the female part of the connector to establish a good connection. Apparently I forgot to take that out before re- installing the ECU and that matching pin got bent and was touching the pin next to it.
I bent the pin back and you would never know, but I don't know if things got damaged inside the ECU. It behaves exactly the same, but who knows.
That's why morons like me should never work on electronics :oops:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Just because a relay clicks does not necessarily mean it's working. You know the contacts are closing but the contacts may be coroded or pitted and not passing current.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
850 LPT wrote: 16 Apr 2025, 14:49 Thanks, Steve
That pin will be fine. Thst does mean the ECU is trying to do some of its work
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
This is going to sound strange, but have you checked the cigarette lighter fuse?
