PCV off to clear oil pan? 2006 XC70
xc70VanIsle
- Year and Model: 2006 xc70
- Has thanked: 3 times
I currently have my PCV and intake all taken apart and discovered the oil pan passage is blocked. Can I reinstall the intake and PCV and do the oil pan cleaning on its own without having to take everything apart again?
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Yes you can. The oil pan job is pretty easy and straightforward. Make sure to get all the parts and seals required before you start including anaerobic sealant. I used permatex for the pan to block.
2003 XC 70 (sold)
xc70VanIsle
So Theres no reason I'll need to remove the breather box again?Blacklab467 wrote: 16 Apr 2025, 06:16 Yes you can. The oil pan job is pretty easy and straightforward. Make sure to get all the parts and seals required before you start including anaerobic sealant. I used permatex for the pan to block.
- Blacklab467
No.
2003 XC 70 (sold)
It usually plugs down in the pan, doesn’t it? Where the channel makes a bend?
- Has thanked: 311 times
- Been thanked: 817 times
Once the bend in the channel (down in the pan) gets clogged, I think it usually fills up quickly to where the pan mounts to the block. They're either plugged to the top or still free flowing, in my experience.
- Blacklab467
2003 XC 70 (sold)
- 1523 Views
Last post by SuperHerman
- 1325 Views
Last post by mkbell2000
- 1061 Views
Last post by Taskmaster
- 806 Views
Last post by oragex
- 25 Replies
- 3431 Views
