DennisCA
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 68 times
Post by DennisCA »
Tried to remove the outer CV joint (broken gaiter). I got the axle out easily enough but the damn retainer ring seems to have broken inside the groove and there's no way to expand it. I am now not sure what to do. Force it off with violence?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
DennisCA wrote: 17 Apr 2025, 11:30 Tried to remove the outer CV joint (broken gaiter). I got the axle out easily enough but the damn retainer ring seems to have broken inside the groove and there's no way to expand it. I am now not sure what to do. Force it off with violence?
Yup, that's about the only option. Lots of hammering!
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Marzzy wrote: 17 Apr 2025, 08:39 Want to fix driver sill emblem. R design. Want to add backup camera. All those years without a backup camera and now I want one. Does anyone know anything about adding thise to a r design?? Note: this car had a small accident right rear corner years ago. And I found some disconnected wire harness where the rear speaker is in the trunk. Any thoughts? I'm not sure where it goes on the rear door . Maybe the license plate light assy? There's 2. Thanks for any help also Revis the cat loves the pics!!
I think you're going to need an aftermarket head unit (radio) and camera...
wizechatmgr
When you go to put it back in, place some decent CV or axle grease all around the ring so it pops in and out easier next time. We had a bugger of a time getting one of mine in until I lubed the shaft.
wizechatmgr
abscate wrote: 16 Apr 2025, 03:20
wizechatmgr wrote: 15 Apr 2025, 17:05 Went to replace panhard/stay on rear of '99 XC today. Found additional damage such as a sway bar mount being destroyed. Hit everything with Fluidfilm for now, will be back under there when I return to US.
Ugh. Still want to know the difference between AWD and XC stays. My life won’t be complete not knowing this.
How did that eccentric bolt look? Definitely heat the nut and turn carefully to avoid breaking, they are NLA but we have spares in stock, thanks to Neil.
My cat turned 126 years old today…my office now has 6 regulator visitors , black, black white feet. And grey not shown
I don't get that many visitors to the office unless we've fricked up in epic fashion. This typically means my unit is on the news. Thankfully that has not happened during my tenure. I think $8B+ without mistake thus far. Zero % acceptable oops factor.
Marzzy
Year and Model: 2015 xc60 R design
Post by Marzzy »
Thank uvm. I wasn't sure if I needed the radio head unit. It looks like the wiring is there. This car was hit in the left rear a few years back. No airbags went off but I think they replaced the electronic lift gate with a standard one. For 55k miles somethings look like they have been worked on underneath the car and not well. Exhaust hanger ect... today xc60 I will try to make a mode of operation list to change the oil. I get the weirdest noise when I give it power l. It feels up front. Like something with the AWD. I'll look further when it's on lift. Oh...also abs module missing. Wonder if this is normal?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
abscate wrote: 16 Apr 2025, 03:20 My cat turned 126 years old today…my office now has 6 regulator visitors , black, black white feet. And grey not shown
Awww...
My office window just popped open and it's adventure land!
BlackBart
Post by BlackBart »
850 LPT wrote: 15 Apr 2025, 14:49 Washed Ingrid the S70 today although she didn't even deserve it.
Look at those seats! 1998??
Has thanked: 2203 times
Been thanked: 1852 times
Marzzy, while you are in the wrong forum for your question, I'm not sure on the head units for Volvo's of that age. I'm going to assume that the head unit currently fitted may not have an input to support the bac up camera.
When I wanted a back up camera, my local electronics store were able to fit a Sony head unit to my 03 Toyota 4Runner. I wired and drilled the hole for the camera wire feed into the tailgate and they did the rest for me.
If you decide to try this yourself, be aware the wi-fi back up cameras can be time delayed. I have know owners to back into objects thet were close up due to the delay.
Good Luck! Maybe try posting in the correct forum area for your vehicle as it is more likely you will find support for your questions there:
viewforum.php?f=26
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
BlackBart wrote: 18 Apr 2025, 15:02
Yes sir. Which is good because no Canbus troubles :)
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
