I like your project. I also thought about using the configuration area search function in my project, regardless of the size of the flash and location. If you have already figured out what file search logic you will use to find the configuration area, can you share?bobbik wrote: 20 Apr 2025, 08:40 I'll rewrite the script to find config block automatically, no matter of dump size and organization. Just give me some time , as spring has come and I do not spend much time on the computer
Vida CEM swapping
Yariy
- Year and Model: XC90
- Has thanked: 16 times
- Been thanked: 10 times
yamaha1024
- Year and Model: xc60
I encountered an issue with downloading VIDA software, can anyone help me? I can pay the fee
dwappertam
- Year and Model: 2001 S60 P2
- Has thanked: 3 times
HI everyone,
I Have a little question about ArduBDM can i use the Program that T5Luke Wrote to read out the CCM flash that uses the same 68376 MCU and a 28f200? The pinout for the ccm allows BDM . i am only want to make a copy of the device...
Thanks in Advance,
I resently tried to use the ArduBDM way from T5Luke for the CEM , finaly got it to read the CEM and retrieved a usefull bin.
Thanks again, this is a life saver ,
With regards
Mike
Thanks in Advance,
With regards
Mike
- RickHaleParker
- Been thanked: 980 times
SAE J2534 and ISO 15765 are the same standards.Treur wrote: 17 Feb 2025, 14:08 I would like to make j2534 out of it. It is already starting to process USB commands, but I need to figure out how to write an API.
ISO 15765-2: Defines the transport and network layer protocols for CAN-based communication, including services like DoCAN (Diagnostic Communication over CAN) and UDS (Unified Diagnostic Services).
ISO 15765-4: Specifies the requirements for diagnostic communication between vehicles and external test equipment, focusing on emissions-related systems and OBD/WWH-OBD (World-Wide Harmonized On-Board Diagnostics) regulations.
You might look through the code for Volvo Tools for clues and examples.
Open J2434 resources.
Active
Past
Past
Treur
- Year and Model: 2007 V70
- Been thanked: 7 times
As it turned out, writing an API is much easier than writing the firmware of the device itself. I wrote the code, but it sometimes works, sometimes it doesn't. Periodically, the controller starts to loop when sending messages. It's hard for me to write in C.RickHaleParker wrote: 22 Apr 2025, 20:45SAE J2534 and ISO 15765 are the same standards.Treur wrote: 17 Feb 2025, 14:08 I would like to make j2534 out of it. It is already starting to process USB commands, but I need to figure out how to write an API.
V70user
- Year and Model: 2003 V70 2.3T5
- Been thanked: 3 times
I tried this project. It didn't work with CEM-B 8688434 . Still the same response : it can't permanently open com port.
If I missing something, I didn't figure out what is it.. till now
It would be the simplest CEM programmer, ever seen
- 10034 Views
Last post by RickHaleParker
- 10496 Views
- 27 Replies
- 32096 Views
Last post by cn90
- 10 Replies
- 12378 Views
Last post by jonesg
- 7285 Views
