A $100 '99 V70 GLT Topic is solved
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
I recognize that piece, but it was on my Audi.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Well I'm hoping that I will be able to figure this out based on finding vacant hoses/ports.
I can't find that diagram on Volvowebparts even when I enter GR72362 which seems to be the page header. It would help to see what each part numbered actually is.
1999 V70 GLT
Has thanked: 1611 times
Been thanked: 4075 times
Heres the part....
Sveedy
Post by Sveedy »
Figures. I pull up that part and diagram, and I want to know what parts 24 and 26 are, but they only tell you what parts 23, 25, and 28 are.
I have figured out where all of the hoses go, except for one open port on this part. Since I still don't have the top of the air filter box, maybe it connects to that. I'll get it sorted out.
On a plus note, I received the camshaft seal, so all of them are now installed.
Parts shipping score : FCP - Phoenix to my post office - 5 days.
Parts Geek - Phoenix to my door - 2 days.
I honestly used to get my parts quicker from FCP when they all shipped out of Connecticut.
1999 V70 GLT
Someone with a low pressure turbo, 1999 model year will have to chime in on that last hose.
The Kat had that, but she has a new owner
Karla has that, but she is in Albany
Wizechatmgr has a 99 XC70 but he is out of the country , too.
Sveedy
Post by Sveedy »
Decided to finish the day on something really really simple. How about putting in the oil filter, so I don't make the mistake of starting to add oil and wondering why it's taken 5qts, but nothing on the dipstick. This is my first cartridge type on a Volvo, and when I went to fit it, it seemed to bottom out by hand way before the o-ring would seal. Without the element the housing threaded on just fine.
Does this look right ?
1999 V70 GLT
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
The angled one goes to a nipple on the ETM's plastic pipe, if it's the same on my '99 XC, next to the MAP sensor.
It's blowby
Sveedy wrote: 22 Apr 2025, 17:17 Decided to finish the day on something really really simple. How about putting in the oil filter, so I don't make the mistake of starting to add oil and wondering why it's taken 5qts, but nothing on the dipstick. This is my first cartridge type on a Volvo, and when I went to fit it, it seemed to bottom out by hand way before the o-ring would seal. Without the element the housing threaded on just fine.
You have to set that cartridge way up and into the engine so that the threaded cap bottoms out the threads or you will have a gusher
It can take a nice firm push to get the cartridge up there
Has thanked: 2210 times
Been thanked: 1852 times
The HPT also has that part. Here are a couple of pictures from my 00 V70R:
GCP ejector in 00 V70R
From your original picture the short pipe should fit to the transmission end of the intake manifold and the ejector orientated this way with the wider end towards the rear of the car.
GCP ejector side outlet to intake tube
The curved pipe from the side of the ejector should face downwards and loop towards the front of the car and attach to the intake tube to the throttle body.
GCP ejector rear pipe
The rear facing outlet pipe runs to the rear of the car. I did not have tome to trace it but it should run to the brake booster.
Hope this helps.
Sveedy
Post by Sveedy »
Perfect ! That's just what I needed.
Thanks Neil
1999 V70 GLT
