Ordered some 5007 tail light bulbs per Sylvania Bulb Guide to replace all 4 in the rear assembly of the 07 S60 2.5T. One was out and the remaining had a few different bulb numbers so decided to go Stage 0. Not sure which website but 67 is interchangeable with the 5007 with 3 more watt output. It's also a round bulb vs the 5007 half circle. Long story short 3 watts is not a lot but it was much crisper, sharper and looked like LED's so more noticeable.
https://www.sylvania-automotive.com/on/ ... &oepn=5007
5007 vs 67 Tail Light Bulbs For 07 S60 2.5T
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- Has thanked: 987 times
- Been thanked: 1075 times
The 67 bulb is rated 78 Watts at 13.5 volts while the 5007 is rated 8 watts at 12 volts. Higher voltage rating generally indicates longer life. Higher watts MIGHT draw enough power to burn fuses.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
or melt plastic sockets.volvolugnut wrote: 25 Apr 2025, 08:15 The 67 bulb is rated 78 Watts at 13.5 volts while the 5007 is rated 8 watts at 12 volts. Higher voltage rating generally indicates longer life. Higher watts MIGHT draw enough power to burn fuses.
- 1311 Views
Last post by Turbo_Boss
- 1046 Views
Last post by Brucebo
- 5112 Views
Last post by AVOIT17
- 716 Views
Last post by Vovo_merz
- 6818 Views
Last post by badbigdad
