1993 850 non-turbo Flooding
Tolsester
Year and Model: '93 850 GLT
Post by Tolsester »
Occasionally, like once every 2-3 months of months, the engine will flood when trying to start.
It always goes like this: Crank, fires, let off of the key, engine dies. This always means it will take me forever to get it started again... I'll either wear down the battery trying to get it started and then recharge, or I need to get a jump start so I can pump air through the engine to dry things out. Then when it starts I have to keep the revs up for about 30 seconds to a minute or it will die again.
When it does finally start, it will fire intermittently as the revs build until the engine can sustain itself without cranking.
This morning I was home alone, so battery charging it was. After the second failed attempt, I removed all the plugs and let the engine air out while the battery was charging.
That got it started, but I still had to keep the revs up while the engine got going.
Other than the typical plugs and wires, what else should I check? (122k miles)
The plugs don't look worn at all (OEM Volvo - original? idk), but looks like I might have some oil in the combustion chamber. PCV?
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Bad maf or ect...or their wiring.
Read the codes...obdI is under the hood.
All you need is a pencil and piece of paper to write down the codes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Do you start the engine with or without giving it some throttle? I usually hit the gas right after cranking. My wife doesn't do that, and I have the impression she stalled/flooded our old 94 10V non turbo alot more frequently than I did.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Maybe check fuel pressure along with codes.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
I agree with the idea of checking fuel pressure. I am suspecting leaky fuel injector or backflow valve next to the tank. I think 850 have a service port which is easy to access so I would start there. Go to harbor freight and get yourself a fuel pressure gauge(or rent from zone or advance if available). Wear glasses and connect gauge to the port. Prime fuel pump several times and check for leaks around connector. If all dry-start car and let it normalize. Check the pressure while running(around 3.5 bars should be norm). Turn engine off and check pressure. (Should drop to 1-1.5 bar and stay there). Leave the car for 4-6 hours and check pressure. If 0psi-either leaky injector or backflow. Start there and keep us posted.
Has thanked: 1505 times
Been thanked: 3818 times
If the engine coolant temperature sensor is old, bad wiring, or aftermarket often these engines will flood on starting. Have a good look at that and measure with an ohmeter when cold. Specs are here in the Fora.
Cap and rotor are wear items and should be inspected, nice and shiny and clean on all brass parts
