Evita seems to gather water in her spare well, happened to me again.
Is this a trunk drain that pops out? Well glued in…..
New solution for cutting semi-circular holes in stuff
P80 trunk drain s70/v70 PSA , clean your trunk drains on (-1998) 850 S70s!
- Has thanked: 2198 times
- Been thanked: 1851 times
Have you considered spreading something like talcum powder in the trunk area to see if you can get a track of where the water is coming in from?
Check the rear light seals, electric antenna seal, and rear windshield. Trunk seal is possible if it is flattened or not glued in some points.
Pretty sure it’s just overflow when the pin oak drops debris into the gasket channel. Right now it’s a clean out once a quarter In the wet season
Well, Matt did a you tube on this I finally found! I’ve never cleaned my drains on my S70s…
Well, I don’t have those drains on my 1999 S70…..they welded them up to give thst extra 2,5 HPboost per side.
- 9 Replies
- 7117 Views
Last post by erikv11
- 2132 Views
- 3267 Views
Last post by matthew1
- 1642 Views
Last post by Schuelke1
- 859 Views
Last post by oldironsights
