If you own an AWD Volvo, at some point you will inevitably have to service/ replace/ remove or repair the angle gear, collar sleeve, various seals or propshaft components. I've done this job many times and hope that this tutorial will help and clarify the job and demonstrate the easiest and most efficient method for many of these tasks. I would say that this job falls well within the scope of the shade tree mechanic in possession of a complete set of basic hand tools. There are countless posts and videos on every Volvo forum on this job, I believe that the techniques that I describe below are the most effective and efficient.
Volvo sells the Collar Sleeve separately and also sells a service kit with the Sleeve and the axle seal (inside the sleeve) plus the transmission housing seal. I'd also recommend replacing the other axle seal on the angle gear at this time.
Disconnect the battery.
Jack up the car in the front and back and get it high enough on jack stands to work comfortably underneath, remove the passenger side wheel and 13mm axle bolt.
Remove the ABS sensor 10mm bolt, Outer tie rod end, and the 2 strut to knuckle nuts.....leave the bolts in for now. No need to take the lower ball joint apart as many suggest.
Next remove the bearing retainer on the passenger side CV axle (12mm x 2) Now you can remove the 2 strut to knuckle bolts and the knuckle will drop, turn it to the right and move the strut to the aft of the wheelwell. There is now plenty of room to remove the CV shaft. If you push the knuckle down there will also be no danger of the strut bottom damaging the CV boot.
I like to lower the exhaust system at this point by removing the 3 rubber hangers at the back of the system and lowering the exhaust system and moving it to the driver's side, as shown in the following illustration. This step is not entirely necessary but only takes a couple minutes and give you more room to work on things at the front.
Remove the front lower bracket (12mm x 4) and use two of the bolts to hold the exhaust heat shield in the correct position as shown below:
Drop the center support (12mm x 4) bolts and rest the propshaft on the hanging exhaust. Do not remove the 2 bolts holding the bearing support assembly.....not necessary.
Remove the 6 6mm hex bolts on the front flange of the propshaft, I use a standard 6 inch hex wrench but you could also use a hex driver and ratchet. This is probably the worst part of this job as its tight in there and you'll have to get creative with where you put your hands and tools! Have the car in drive so you can rotate the propshaft to access all the bolts. Once all the bolts are out you should be able to wiggle the propshaft CV out of the flange and move it to the passenger side of the flange, out of the way. The rear flange on the Haldex end gets rusty and can be a real PITA to separate most times. You may consider removing the propshaft completely at this point if you need to change the Haldex pump. The filter can be changed with the shaft in situ.
Remove the angle gear: there are 5 14mm bolts holding it on, 4 can be easily seen, the 5th one is on top and can be reached by a shallow 3/8 socket and 12 inch extension. I use a common box end wrench to remove the 4 visible bolts. Once all the bolts are removed, support the angle gear and move it laterally towards the passenger side until it is off the splines of the collar sleeve....about two inches. it weighs about 30 pounds so don't drop it on your face or hands. Once its free it's a bit of a puzzle to get it out the bottom, I turn the flange end up and maneuvre the bottom of it out first. You don't have to bend the skid plate mounting tab out of the way but many others recommend doing so.
Now you should have a clear view of the collar sleeve and can check condition of the splines as well as the angle gear input shaft splines and can determine which parts warrant replacement. This tutorial covers R&R of the collar and transmission seal only.
Removal of the collar! Probably one of the most intimidating tasks in all of the Volvo forums worldwide. They can sometimes slide right off with almost no effort or stay put with the force of a 5 ton press on them. I came up with my own method after trying several presses, pullers, etc. that were ineffectual. Volvo uses a hydraulic press purpose built to remove these, clearly I don't have access to one of these. This time, I purchased a blind hole expandable collet puller in effort to find a cleaner way to remove the sleeve, I was dissappointed with the results after an hour of hammering and heating the sleeve with a heat gun, it did'nt budge. This picture shows how the puller attaches on a sleeve that is already removed.
My proprietary tried and true method came next, namely cutting two small grooves in the collar with a 4 inch angle grinder 180 degrees apart and using these primitive tools: A masonary chisel and a 14oz ball pein hammer!
I've used this method on many stubborn sleeves and find it to be the quickest and most effective. the photo below shows the approximate angle to strike the sleeve. I give it a half dozen hits on one groove, then rotate it and give it 6 more hits on the other side. The sleeve will be off in 5 minutes of this being repeated several times.
With the sleeve out, you'll lose about 3/4 of a litre of transmission fluid.
Replace the large seal on the transmission output, VIDA has this seal being installed AFTER the new collar sleeve is on with a special seal driver that fits over the sleeve. I prefer to replace the seal before the new collar sleeve gets installed. Special seal drivers below carry the part number: SD2X4 as seen below:
Install the new Collar Sleeve: The service kit has Volvo's hygroscopic grease in a tube to be applied to the splines. Make sure everything is super clean and put lots of transmission fluid on the seal and collar also. Offer up the collar to the splines and gently tap the collar with a plastic hammer. I've seen videos of people that hammer the sleeve all the way on, also people that get it on part of the way and then use the angle gear to press it in using the AG attaching bolts. From an automotive fundamentals perspective; both of these techniques are wrong. I built a simple press out of sturdy L Iron to press the Collar Sleeve in. If you've not done this job before there is small interference fit on the splines on the transmission, not so on the angle gear input shaft splines. The sleeve needs to be installed such that it protrudes 41mm proud of the seal bore.......this number is important!
Reinstallation of the angle gear, propshaft, CV shaft, etc. is essentially the reverse of removal. Torque all bolts to spec and use a new axle bolt and new strut to knuckle bolts upon reinstallation.
Angle gear collar sleeve and seal replacement Pictorial, 2003 XC70 automatic.
Angle gear collar sleeve and seal replacement on 2003 XC70
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
- Chisel and collar.jpg (50.29 KiB) Viewed 3462 times
- Collar press in use.jpg (47.48 KiB) Viewed 3462 times
- Parts.jpg (57.43 KiB) Viewed 3462 times
2003 XC 70 (sold)
- Has thanked: 1611 times
- Been thanked: 4072 times
Check your part numbers on the angle gear oil. Volvo spec s a low foam gear oil for the angle gear, different than differential oil.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
That wheel hub stretching the brake hose... =)
Does not need separating strut from the hub fully, just remove the upper bolt, slacken the lower and turn the hub. There will be just enough space to take the axle out of hub. You may first think there's no space and it can't be done, but there's space
Also never had to lower the exhaust.
Blind hole puller worked for 200 lbs of me every time.
- Been thanked: 504 times
Great job.
My 2005 XC90 2.5T AWD has been a FWD for > 10 years.
Glad I did not fix this issue bc the sleeve design is very bad.
Some ppl go through 4 sleeves in years.
I just don't have the "appetite" to do it.
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
In photo 10 where you're showing the chisel angle, are you mounting all that in a vice and then knocking off the end?
- Blacklab467
No, that was just for demonstration, you have to remove the collar sleeve from the transmission output shaft. Its what connects the angle gear splines to the transmission output splines so it has female splines on the inside of the collar. They're bonded on in some years and models and the splines have an interference fit, hence they can be quite a challenge to remove!
2003 XC 70 (sold)
vtl
Bonded how?Blacklab467 wrote: 30 Apr 2025, 17:18 No, that was just for demonstration, you have to remove the collar sleeve from the transmission output shaft. Its what connects the angle gear splines to the transmission output splines so it has female splines on the inside of the collar. They're bonded on in some years and models and the splines have an interference fit, hence they can be quite a challenge to remove!
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
I used angle grinder to make 3 cuts in the collar sleeve and used a puller to remove collar sleeve. Mine was also "bonded" by years of contact and slide hammer was a weak sauce.
- Blacklab467
Vti, my understanding is that some of these sleeves in certain years were bonded, possibly mostly P80’s or M55’s of specific years, I’m assuming with a specific bonding cement. Many have documented on various Volvo forums having to remove adhesive remnants from the transmission output spline after removing the sleeve before installing the new one.
The expandable collet puller I bought from Amazon was $90 and of questionable metallurgical quality so I didn’t want to hammer on it too hard for fear of breaking it off in the collar. My main ambition was to try and save the collar upon removal because I’d just installed it a month prior and had developed a seal leak afterward.
2003 XC 70 (sold)
- 4329 Views
Last post by darrylrobert
- 611 Views
Last post by neilmullen
- 36 Replies
- 19239 Views
Last post by ggleavitt
- 524 Views
Last post by XCbandit
- 2796 Views
Last post by erikv11
