Hi all does anyone have a wiring diagram for a 2003 volvo v70r abs module
I've recently bought a volvo v70r with fault codes, the wiring for the abs module has been chopped and joined again so im trying to diagnose someones mistakes, the best I could find is a diagram for a xc70 and the wire colours are in the wrong placed for 3 wires, they are wires relating to my fault codes so just wanted conformation that I've found my issue, any help would be grate thanks all.
You will need diagram for you model and UK market as thst stuff is country specific
Ahh right. I might find that quite hard to find then, as it's a Japanese import.
thanks for all the information and help I'm gonna try contact a dealer to see if they could supply one for the exact car if I'm lucky.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
3 wires can't be too difficult to sort out.Volvoror wrote: 12 May 2025, 12:45 I've recently bought a volvo v70r with fault codes, the wiring for the abs module has been chopped and joined again so im trying to diagnose someones mistakes, the best I could find is a diagram for a xc70 and the wire colours are in the wrong placed for 3 wires, they are wires relating to my fault codes so just wanted conformation that I've found my issue, any help would be grate thanks all.
find the constant 12v feed with a meter.
Then ground,
the 3rd wire should be the 5v signal....don't feed 12v battery power into that wire,
use a computer safe probe, mine only allows 500milli v.
- 939 Views
Last post by rice240
- 2605 Views
Last post by legalstuff
- 1866 Views
- 10 Replies
- 10246 Views
Last post by JDS60R
- 4162 Views
