Hi all, in tropical area where I live, is there any potential problem if we delete the heater core permanently? would cooling capacity decrease for the engine & tranny?
Thank you in advance
Bypassing heater core 2004 S60
- volvothaifactory
- Year and Model: 2004 S60
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I would imagine it would be negligible, since when you do not use the fan to blow on the heater core, it already saturates with heat and I doubt the small surface area with just radiation alone could affect temps in any positive matter.
What would be better for temps is installing a second fan behind the front bumper that could kick in earlier than the main engine fan. These cars have very ineffective cooling from the water pump at idle. I even thought about installing a second, electric pump to circulate the water at idle more effectively. But it was only a passing thought.
- volvothaifactory
I agree with the ineffective cooling on these cars. By extra fan you mean a visco fan? I already imagine the struggle putting it in, in already cramped engine baydikidera wrote: 15 May 2025, 03:03 I would imagine it would be negligible, since when you do not use the fan to blow on the heater core, it already saturates with heat and I doubt the small surface area with just radiation alone could affect temps in any positive matter.
- volvothaifactory
do you know some good OEM ones?vtl wrote: 15 May 2025, 05:00 Go ahead. And add extra transmission cooler. May bypass heater exchanger in radiator altogether.
- volvothaifactory
I see, just consult with my local volvo specialist, these things worn out the seals faster, and could be troublesome for the tranny in the long run he saidvtl wrote: 15 May 2025, 15:10People fit XC90 ATF coolers in with minimal efforts. I have just a generic Hayden ATF cooler in line with heat exchanger and no thermostat, it works well.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
What? Find another one.volvothaifactory wrote: 16 May 2025, 01:54 I see, just consult with my local volvo specialist, these things worn out the seals faster, and could be troublesome for the tranny in the long run he said![]()
dikidera
Not even remotely true my guy. But you will need just a bit more atf, to compensate for the added volume of the cooler. I have not installed an AUX cooler yet, but I do have an external filter with strong neodymium magnets attached to it(emulating Magnefine but poor mans solution)volvothaifactory wrote: 16 May 2025, 01:54I see, just consult with my local volvo specialist, these things worn out the seals faster, and could be troublesome for the tranny in the long run he saidvtl wrote: 15 May 2025, 15:10People fit XC90 ATF coolers in with minimal efforts. I have just a generic Hayden ATF cooler in line with heat exchanger and no thermostat, it works well.
1.jpg![]()
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
I did the heater core bypass a few summers ago. I will be restoring it to original when i get the chance. I can see if i can take pictures of it tomorrow oh and my car is stick. The amount of coolant going to the heater core is very little.
As for the engine fan, even on hot days mine hardly activates, ive had to check it in VIDA to confirm its still working.
I modified my cluster a few years ago with this OBD2 temp/speed TFT display that reads of the cars computer. the temp while driving sits around 90c but stop for any length of time and it goes up . i have the alarm set at 106c and have not had it activate even on 35c days
- switch for heater core mod
- switch mod.jpg (50.75 KiB) Viewed 444 times
- 12 Replies
- 2114 Views
Last post by humbertoflores63
- 11 Replies
- 9794 Views
- 5058 Views
- 11 Replies
- 3471 Views
Last post by cn90
- 1636 Views
Last post by vvvolvo
