DIY: 1998 Volvo S70 GLT PCV Mod: no more smoking dipstick!
The Ultimate PCV Fix DIY
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
And when you say " off the shelf ", do you mean it's a pre-formed heater hose ?
1999 V70 GLT
1999 V70 GLT
- Has thanked: 312 times
- Been thanked: 818 times
He's saying he used the pre-formed hoses sold by Volvo for that part of the PCV, e.g. https://www.fcpeuro.com/products/volvo- ... -1271654-1 etc. And definitely not heater hose!Sveedy wrote: 10 Dec 2021, 16:11 And when you say " off the shelf ", do you mean it's a pre-formed heater hose ?
- Sveedy
That's what i was thinking, but wanted to be sure. I have a couple of those kicking around, Somewhere....
1999 V70 GLT
1999 V70 GLT
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
According to SimplePart, both 1271654 and 9146757 fit. The upper picture looks like 9146757, which is what I bought 2 years ago for my 1996 after going to Volvo Parts Webstore and entering my car info. I thought the original 1271654(probably) seemed like a better fit, going through the other opening in the intake manifold.erikv11 wrote: 10 Dec 2021, 16:38He's saying he used the pre-formed hoses sold by Volvo for that part of the PCV, e.g. https://www.fcpeuro.com/products/volvo- ... -1271654-1 etc. And definitely not heater hose!Sveedy wrote: 10 Dec 2021, 16:11 And when you say " off the shelf ", do you mean it's a pre-formed heater hose ?
Yes, even though some of the IMs have something in the way there (can't remember what) which is why Volvo made different hoses, both will work.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Well, perhaps. The '97 GLT has the FPR down low behind the engine. My '97 T5 has it up top.erikv11 wrote: 10 Dec 2021, 12:12
Ah ok, thanks.
I thought the difference in those two was because of where the FPR is located, but then again I also thought it was more clearly connected to NA/turbo differences. Obviously that last point doesn't hold up for your two cars.
Even with the '01 LPT RN swap in her car, we used the accessories and intake/rail/etc from her '97 engine.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I am thinking of installing an elbow / 90 degree bend in the main pipe, similar to what you showed in the photos of your installations. Would you be able to tell me what type of fitting you used, where you got it, and how you installed it please? Thanks.
- Chuck W
It's just a 5/8" 90* plastic barbed fitting. Similar to THIS but shorter legs. (You could also cut that one down). I just cut a short length of hose, long enough to join it too the separator but not have it be too tall (thus mentioning cutting down the legs on the fitting) and just crimping it all together with the Oeticker clamps.jreed wrote: 12 Dec 2021, 06:14 I am thinking of installing an elbow / 90 degree bend in the main pipe, similar to what you showed in the photos of your installations. Would you be able to tell me what type of fitting you used, where you got it, and how you installed it please? Thanks.
Redmerlebaby
- Year and Model: 2001 V70 t5
Got an update on longevity of this trick? Lots of people online saying the oil would break down the heater hose, but could just be fear mongering I'm not sure.
Also thoughts on 5/8 fuel line instead?
Redmerlebaby
- 30 Replies
- 9400 Views
Last post by Ben850
- 15 Replies
- 3346 Views
Last post by rspi
- 30 Replies
- 6651 Views
Last post by matt122s
- 31 Replies
- 5461 Views
Last post by callahanoffroad
- 1029 Views
Last post by mika
