Has thanked: 1851 times
Been thanked: 1712 times
Anything from 13.8-14.2 is normal without a load (headlights, heater fan, large power draw items)
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
scot850 wrote: 22 May 2025, 10:25 Anything from 13.8-14.2 is normal without a load (headlights, heater fan, large power draw items)
Well headlights are always on. I suppose I could find the fuse and pull it, for a test. I forget about the lights always being on pulling the voltage down.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
With the headlights on I would expect 13.5V or in that area. I'm no electrical expert, but having the headlights on is 2 x 55W? = 110W/12V
That is only 9A draw down on a 100A (-98) or 120A 99- alternator charging a 600CA battery. If your alternator is only outputting less than 13V then maybe you have a concern, like maybe worn brushes or voltage regulator?
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
Probably wasn't necessary, but I went ahead and replaced it anyway.
1999 V70 GLT
Has thanked: 1506 times
Been thanked: 3819 times
Are you done with that mount??
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I replaced the boots on my passenger axle
Old boot:
Split in boot -- time to replace
Newly re-booted axle installed in transmission with new Corteco seal:
Axle back in place
Axle back in place
Axle reinserted into steering knuckle:
New outer boot back in place on steering knuckle
I used the GKN Lobro outer boot... last one endured about 10 years. Hoping for similar longevity with this one.
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
abscate wrote: 20 May 2025, 18:00 Hot weather states have battery life of ~ 5 years…I think you are an Okie right?
Here in Texas I end up replacing batteries every 3 years. It wasn't always this bad. Makes me wonder if there has been a change in the way batteries are constructed over the last 30 years.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
ZionXIX wrote: 26 May 2025, 07:35
Oh 100%. The last battery in my mom's XC90 lasted about 9 years, it was a genuine Volvo battery. I replaced it in 2020, still going strong with an Everstart from good ol' Walmart.
What I have noticed is that interior mounted batteries tend to last a lot longer than engine bay mounted batteries. More protection against the elements and heat.
454cid
Post by 454cid »
bmdubya1198 wrote: 26 May 2025, 09:20
I've never been a fan of mounting batteries any place but the engine bay, as it always seemed more complicated to me. It was all based on hearsay and assumption, Though. I now have one battery in the trunk, and that's on my 1996 C220 (W202) Mercedes. It was dead when I bought it, but after a long slow recharge, it's been absolutely fine.
I still don't like the idea of putting it under the back seat, However. Both Mercedes and GM have done that. I guess that's probably better than in the wheel well, as I've read that where some cars have it.
I also usually buy Everstart batteries. It's what's in my 850, which hasn't gone dead again, but I've been driving it more, too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
bmdubya1198
454cid wrote: 26 May 2025, 09:46
Chrysler did the fender liner batteries in the late 90s and early 2000s... dumb location! There's also a lot of vehicles now that put them under the passenger seat/floor. Really stupid.
BMW E34s are under the rear seat, not a fan of that either. Trunk is my favorite location.
