P1332 (Knock Sensor) and P0014 (Cam Timing) – Could This Be ETM Related? [1999 Volvo S70 GLT]
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Why did you replace the front mount? Was it leaking? Engine vibration? Were all mounts replaced? Did you notice a difference with the new mount?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- ericmci
- Year and Model: 1999 S70 GLT
- Has thanked: 73 times
- Been thanked: 15 times
The rear had split and lost all it's fluid.
But the rubber alone was keeping it fairly steady.
And the side pad kind of needed it. But I think they were all original and honestly it's not a huge difference
But one of those repairs I wanted to do all at once to equalize the repair effect you know?
So I did them all at once.
I would say the trans torque mount made the biggest difference- also the easiest one to do.
I *Can see a difference after it is more steady at idle and load.
It was worth it.
But more of a nice thing to have than an essential for my car.
Much like the subframe bushings I have in my garage waiting to go in.
It was worth it.
- ericmci
I just realized that I could check the part number with my boroscope
and it is in fact the Camshaft Position Sensor.
For my car it is 9186811
I love this little bit--
This year has some really weird 'quirks' when it comes to parts and manuals:
Camshaft Position Sensor – Volvo S70 GLT (9186811)
Volvo Part Number: 9186811
Application: Camshaft Position Sensor
Mounting Location: Despite being listed in some places as for the "exhaust cam", in your Volvo S70 GLT (especially 1999–2000 models with CVVT on the intake cam only), this sensor is physically mounted on the end of the intake camshaft.
Why Does It Say "Exhaust Cam" Then?
This is where the confusion often comes in:
Parts catalogs and aftermarket sellers sometimes refer to it as an “exhaust cam” sensor because in other later Volvo engines (with dual CVVT), there are sensors on both cams, and the naming convention stuck.
On your 1999–2000 S70 GLT, CVVT is only on the intake camshaft, and there's only one camshaft position sensor — and it monitors the intake camshaft.
The sensor is installed at the rear of the cylinder head, which is the transmission side — this is often mistaken for the exhaust side due to the turbo being nearby, but it’s still mounted on the intake cam.
jmartin919
Would you say the trans torque mount took out a lot of the vibration at idle in Park and Drive? Do you know which brand you used? I bought a Febi-Bilstein and it was so flimsy I sent it back and put the original back on.ericmci wrote: 26 May 2025, 08:10 The rear had split and lost all it's fluid.
It was worth it.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- ericmci
It can affect it- it definitely made a difference in shifting through park- Drive.
I would also point to the front mount.
I didn't know mine was split until I removed it. The weight of the engine keeps it feeling pretty firm
and any sign of a leak was long gone.
I got my mounts from FCP but this one seems to be out of stock by:
Hutchinson - Lower Transmission Torque Mount
Just always stay clear of URO
jmartin919
For those interested. A disected OEM rear engine mount from a 2000 S70 GLT SE that was leaking.
. I saw in another thread that aftermarket mounts maybe solid rubber and not hydraulic. I did replace my rear mount with a Corteco so maybe that's why I have the vibration?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- ericmci
Well it doesn't appear that my P0014 was coming from a dirty sensor.
Good news - my seal is intact.
But the next trigger for this code would seem to be try cleaning the cvvt.
And doing a final confirmation of the timing marks.
I suppose the Camshaft Position sensor could be faulty itself - but would that present itself all the time?
Here is the shiny sensor.
There is some very light scoring on the bottom but it was pristine clean.
- 4484 Views
Last post by z80
- 12 Replies
- 1661 Views
- 2040 Views
Last post by cn90
- 23 Replies
- 2565 Views
- 32 Replies
- 8379 Views
Last post by SoCalV70T5
