Hello,
I have this code 0089.
I did buy a fuel pressure regulator and looked for it on the fuel rail
There is no FPR on the rail on my car.
2006 Volvo s80 (same engine 2.5 as the s60)
I'm being told it is a regulator or some component in the back near the gas tank on top of the gas tank.
Anyone one else have this issue and find a solution ?
My tags expired May 31st in less than a week. So I would like to pass emissions n in Virginia.
Thanks!
P0089. Help! Virginia license plates expiring. Help!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Your model year has fuel pump control module (PEM) and no mechanical regulator. What you can try replacing is fuel pressure sensor. Otherwise read the Volvo codes, with DiCE/VIDA. This car tells clearly what it dislikes in most of cases.
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
Ok the dreaded PEM.
I know there is a cheap one, and a super expensive one. I guess it goes by vin? Or if I find out where the PEM is I can get a part number off the unit, no?
The fuel pressure sensor looks new (driver side of fuel rail, grey in color, correct?) but I can always replace and re-test.
I work in an auto shop, Porsche, but I don't think the guys have a DICE/VIDA code system. I can ask the techs and see
Thanks for the ideas to point me in the proper direction, anything else?
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
- Been thanked: 4071 times
You can get a used PEM for under $100
surfbug1
Should I shotgun the PEM? The fuel pressure sensor was replaced OEM before I bought the car. (but maybe it's bad outta the box)
I can do that, buy a PEM off eBay and toss it in there, I am good and buying Volvo stuff! Hahahaha
Where is the thing located. (I will search YouTube vids)
Any one help me with a part number?
Vin number is
YV1 TS5 926 614 xxx xx (last 5 redacted)
Vin number is
Ping me!
Ping me!
surfbug1
surfbug1 wrote: 28 May 2025, 13:29 Should I shotgun the PEM? The fuel pressure sensor was replaced OEM before I bought the car. (but maybe it's bad outta the box)
Vin number is
Did some research and I got a pem coming from eBay for very inexpensive!. Now I just have to find out where the thing goes and replace it.
Been watching YouTube videos.
It looks like it's tucked up between the bottom of the trunk and the top of the tank gas tank. Also they say it could be in the passenger rear wheel well underneath a plastic protective cover. Or inside the trunk on the passenger side.
I will keep everyone updated! Thank u
Ping me!
Ping me!
ortho stice
- Year and Model: 2006 XC70
- Been thanked: 5 times
I pulled a spare PEM from a '06 S80 in a junkyard to keep in my XC70. On both cars I'd seen it was stuck to the passenger side of the trunk storage area by the spare.
surfbug1
ortho stice wrote: 29 May 2025, 07:18 I pulled a spare PEM from a '06 S80 in a junkyard to keep in my XC70. On both cars I'd seen it was stuck to the passenger side of the trunk storage area by the spare.
That's great news! Hopefully it'll be easy access, I will check the trunk area on my lunch break. Thank you!
Ping me!
Ping me!
