yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Started prepping the trusty s60 for sale. Need to do an oil change, rear rotors and pads, and detail it. Put a fair amount of money into the car but it has been good to me for the past two years of ownership.
Car has been great to me, but i've inherited a 12' pilot fully loaded. That needs a bit of work, but the size, fuel economy (9L/100km premium normally vs 9.8-11), and towing capacity has me set. It too will need a timing belt and water pump soon, cant escape that.
The older volvos in the fleet will see a lot more love coming up.
2008 S60 2.5T Auto (Sold)
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
yanga001 wrote: 20 May 2025, 12:41 Started prepping the trusty s60 for sale. Need to do an oil change, rear rotors and pads, and detail it. Put a fair amount of money into the car but it has been good to me for the past two years of ownership.
Where are you located? You can message me if you feel more comfortable doing that. I may be interested in your car as is.
04s60 2.4
04xc70 2.5t
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
i am almost finished a front (cat cam) camera installation, activated by a contactless proximity sensor mounted on the gear stick (manual)
the sensor activates when a metal object (gear selector arm) swings into range
SN04-N 4mm PNP Approach Detect Inductive Sensor Proximity Switch DC 10-30V
Alpine ilx-702d headunit
PNP proximity sensor
cat camera
cat camera
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
Very nice, I would've personally also installed a night vision module such as the ones from Mercedes. But where did you put the front camera?
dikidera
Post by dikidera »
We just had a massive hailstorm, no broken windows on the S60, but waiting to assess paint/body damage.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Yike - your planet has big hail?
BlackBart
Post by BlackBart »
I just sent an order in to FCP including a RF axle seal, Corteco 9143885. Is that the correct one? (2004 XC70). They have two versions, but this appears to be my application. I wrote them to verify. Not sure I need it, but if the axle is coming out, I felt I should have it on hand.
Thanks -
BlackBart
Post by BlackBart »
FCP wrote right back - very nice - to say yes, that’s the correct axle seal. I had them add the updated intake banjo bolt while I had them on the line.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Started tear down of the front suspension on the 05 XC90. LCAs, sway links, in/out tie rods, ball joints, CV shafts too while I’m there (208k miles). Did loaded struts 7k miles ago and was clear rest of suspension needed done.
Driving in ball joints gets me every time. May take the steering knuckles to a local shop in morning to have them install them. I recall on here someone used a short piece of 1.5” capped steel pipe. Home Depot only had PVC in that size lol. May try Menards, local O’Reilly may have a tool too.
08 C702.5T (sold)
The non-Swedes:
Krons
Post by Krons »
Krons wrote: 30 May 2025, 22:26 Started tear down of the front suspension on the 05 XC90. LCAs, sway links, in/out tie rods, ball joints, CV shafts too while I’m there (208k miles). Did loaded struts 7k miles ago and was clear rest of suspension needed done.
I surrendered and paid the local shop $90 to install the ball joints. XC90 drives much better, the steering wheel is now straight vs slight cant to it.
Bad news at alignment shop…I was running out of time for my 4pm appt (as well as energy and emotional fortitude) and skipped the inner/outer tie rods as the outers looked fairly new. Whelp the inners have a teeny bit of play in them. Frustrating as I checked them and did not feel any. So we’ll tackle that one another day, at least no bill for an alignment…
08 C702.5T (sold)
The non-Swedes:
