Long term results for 2001 V70 auto transmission drain and fill
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
That dirty fluid is usually a sign of bad torque converter clutch. Just burnt ATF is brown, not black. If you put one drop of your old fluid on a white paper towel, you'll see worn friction particles.
Also need to check ATF level with the engine running, or the level will be high.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
vtl wrote: 01 Jun 2025, 20:19 That dirty fluid is usually a sign of bad torque converter clutch. Just burnt ATF is brown, not black. If you put one drop of your old fluid on a white paper towel, you'll see worn friction particles.
I still say it's partly because of old fluid(previous owners) + slipping lockup function leading to this disaster. All transmission posts + 2 of my own I've seen have had the same color(brown or worse).
