850 feels like it it's missing
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Wow, that is a hole alright. And the color and deposits on those two valves are different from all the others - but that could have been from after it burned through.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
You know that's a good point I hadn't considered.....
1999 V70 GLT
1999 V70 GLT
- Sveedy
I noticed that the machine shop that rebuilt this engine, used a liberal amount of anti-seize on the head bolts. I didn't think that was the recommended procedure for these engines. If it's not, could this have had anything to do with oil getting into the cylinder and causing the burnt valve ? I'm thinking that now I'll have to clean out the bolt holes on the block to get rid of that compound.
1999 V70 GLT
1999 V70 GLT
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Is it really anti-seize, or is it possibly a thread sealer? Do the bolts go into the water jacket? I'd go for whatever Volvo specifies, as that's the best way to get a good torque.Sveedy wrote: 02 Jun 2025, 09:41 I noticed that the machine shop that rebuilt this engine, used a liberal amount of anti-seize on the head bolts. I didn't think that was the recommended procedure for these engines. If it's not, could this have had anything to do with oil getting into the cylinder and causing the burnt valve ? I'm thinking that now I'll have to clean out the bolt holes on the block to get rid of that compound.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Sveedy
No it's anti-seize. My hands looked like the tin mans after handling them.
1999 V70 GLT
1999 V70 GLT
fredt2
- Year and Model: 850 GLT 1995
- Has thanked: 2 times
- Been thanked: 7 times
afaik, you aren't supposed to put anything other than oil on these bolts, and yes, when you're putting it back together, get the threads and bolt head slightly damp with oil, that is to lubricate the bolts when you torque them down, if not you risk getting the head to surface torque instead of head to thread. But asking your question, probably unrelated to your burnt valve
- 1273 Views
- 310 Views
Last post by jreed
- 1153 Views
Last post by precopster
- 690 Views
Last post by shiloh51933
- 1165 Views
Last post by s2zeller
