About 8 months ago I picked up a new-to-me '98 V70 NA manual that I've been fixing up and modifying. Now that it's finally getting warm out, I've started to dig into the non-functional AC. For reference, this car has the simple MCC system, with manual everything and cable-driven blend doors.
When first filling the system, the compressor was cycling normally. It then stopped cycling a minute or so later, despite the system being nowhere near full. Here's what I've tested so far:
- High-side pressure switch tests as it should, and jumpering the connector does nothing
- The AC fuse tests good
- The AC relay bench tests good. I also swapped it for a known-good relay out of my other '98 with no change.
- If I jumper the relay socket in the fuse box with some wire, the compressor clicks on just fine and sounds good
- Testing for activation voltage at the relay in the fuse box, I only see 0.55V
I'm at a loss for what the problem could be. Anyone have any ideas?
Another Car, Another Climate Issue. AC This Time. Topic is solved
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Has thanked: 2200 times
Have you checked the clutch gap? There are specs for it and what is called the zip-tie/bread clip repair to shim it into spec.
I can't recall, but do MCC cars have the cabin temp monitors above the grab handles?
- V50M66
Haven't checked the clutch gap, but that likely wouldn't be an issue here, as the compressor flat out refuses to click on under any circumstances. I'm not getting activation voltage at the relay.
It'll click on just fine if I jumper the relay to force 12v to the compressor, but refuses to do anything else otherwise since it's not sending 12v to click the relay on.
No temp sensors for MCC
I believe on the 1998 the AC command control comes from the MCC, in 1999 it comes from the ECu. There might be a chassis break change in the model year….gulp. Post up last six of your VIn and build date
You’ve. Only got a month of summer left, anyway.
- V50M66
Funny enough, I actually started down this road because I was going to delete the AC. Got the delete belt and everything. Went to remove hardware, double checked there was no refrigerant in it first, and it was almost half full, so I figured there might be hope.abscate wrote: 02 Jun 2025, 20:56 I believe on the 1998 the AC command control comes from the MCC, in 1999 it comes from the ECu. There might be a chassis break change in the model year….gulp. Post up last six of your VIn and build date
This is a very early ‘98. Built in early ‘97, and has the external slave, single-mass M56 in it. I believe the change to ECU-actuated AC compressors was for the changeover to ME7 engine management for the ‘99 model year.
- V50M66
Replaced both high and low side pressure switches today with no change in behavior.
Tested for 12V at the high-side connector and it’s doing what it should, so no issues there.
Not sure where to proceed from here.
Is the 12 volt command coming from the MCC module to the compressor clutch?
- V50M66
I'm not sure if there's a command coming from the MCC - I have no way of reading data from that module (the app only supports ECC, though VIDA makes no mention of being able to read it even with the VIS so perhaps MCC really is that archaic).abscate wrote: 04 Jun 2025, 04:03 Is the 12 volt command coming from the MCC module to the compressor clutch?
I do know I'm not seeing activation voltage at the relay, so something is preventing the signal from reaching the relay. It did work for about 30 seconds when first filling the system, but after that, nothing.
- V50M66
Replaced the MCC today, with no change. Not sure where to go from here. I did find the wiring diagram for the MCC system:
...though I'm unsure what exactly I should be testing, if it should be seeing voltage, etc. Any electrical nerds have any ideas?
- 25 Replies
- 7085 Views
Last post by Blacklab467
- 2080 Views
Last post by foggydogg
- 1136 Views
- 10 Replies
- 1494 Views
Last post by rguzz
- 3489 Views
Last post by caliwagon
