Odd battery/starter issue...00 v70xcse Topic is solved
levalexi
Year and Model: 2000 v70 xc se
Has thanked: 9 times
Been thanked: 6 times
Post by levalexi »
My v70 has always radiated heat from the engine bay. That's no secret. It doesn't overheat at all.
The issue is either the battery or starter.
In the summer months, I'll drive somewhere, park, shut the car off and do whatever.
I'll get back and go to start the car, and it won't start. It acts like a dead battery where you turn they key and it clicks.
The Battery is brand new and fully charged. This happened with my old battery too.
I'll pop the hood and let the engine bay cool down for 10 minutes or so, and then it'll start again like there wasn't any issues .
Has anyone else run into this?
jmartin919
Year and Model: S70 GLT SE 2000
Has thanked: 97 times
Been thanked: 42 times
Post by jmartin919 »
Fuel pump relay?
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
levalexi
Post by levalexi »
jmartin919 wrote: 06 Jun 2025, 12:44 Fuel pump relay?
No,I forgot mention that it acts like a dead battery, where you turn the key and click.
I'll update the post.
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Starter likely getting ready to go.
2023 Lexus RZ450e -66k
Has thanked: 2209 times
Been thanked: 1852 times
Likely the starter, followed by the electrical portion of the ignition switch.
levalexi
Post by levalexi »
I'll give it a shot and replace it when I can.
It works fine every other time. I daily drove it back when it happened the first time over a year ago. It just seems to be when it gets hot out.
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I had an intermittent symptom like this on my 97 855 and the root cause turned out to be high resistance inside the positive battery cable at the terminal post -- the crimp was failing, leading to a large voltage drop. You can measure the voltage drop between the battery and the starter and see if it's higher than normal when you're trying to start the car (should be below ~0.2V). In my case replacing the cable fixed the issue.
levalexi
Post by levalexi »
jreed wrote: 07 Jun 2025, 06:08 I had an intermittent symptom like this on my 97 855 and the root cause turned out to be high resistance inside the positive battery cable at the terminal post -- the crimp was failing, leading to a large voltage drop. You can measure the voltage drop between the battery and the starter and see if it's higher than normal when you're trying to start the car (should be below ~0.2V). In my case replacing the cable fixed the issue.
My buddy's looking at it tomorrow for me. I'll have him give that a look.
I was chasing a no start issue last year, but it was because of the terminal end on the solenoid, so this is a possiblity.
I'm just not understanding why it's only on hot days after the car has been driven.
Let us know how it goes. I still suspect the brushes are worn out on the starter.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
I also vote for bad/corroded battery cables.
Symptoms are magnifying with heat soak.
2awg(25mm2) wires should be used as a replacement.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
