No Start or Crank (I'm pretty much confused) Topic is solved
S70GUY
- Year and Model: S70, 2000
I'll describe this as briefly as possible: I have a strange problem with my car and I don't know what it is, It's already giving me a headache and I don't know exactly what to do about it.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Engine is cranking but cranking is weak.
Not enough power to start the engine.
I would say that battery is almost flat since odometer & trip readout is blank(------).
'99 & '00 needs a healthy battery voltage to start and run since they have DIS(distributorless) system.
11.9v is flat battery.
Try to jump start it or put a good battery.
When we rule that out...then you need to inspect battery cables for voltage drop.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
You should have total mileage displayed in upper row and 0.0 in lower row if it's because of bad abs module...since mileage is stored in the cluster not abs module.
You can power up the cluster on the bench and it will always display total mileage stored in the cluster.
Total mileage folows the cluster...not the car.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
I agree with what misha is saying here. The 99 and 00 need more power and will have a no crank no start issue.misha wrote: 08 Jun 2025, 02:32 Engine is cranking but cranking is weak.
A bad (low capacity battery) can cause this issue too. Had this happen when my battery dropped to 50% capacity over time. The car refused to crank/start but would have enough power to show the display.
2008 S60 2.5T Auto (Sold)
- misha
That doesn't matter....the battery shows voltage of 11.9v.That is flat battery.
Full battery must read 12.7-12.8v.
12.2v is 50% charge.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 987 times
- Been thanked: 1075 times
If the electrical charging system is not right, the battery will lost charge (go flat) over time. Even as few months old battery will lose charge unless charged by the alternator system.
- Has thanked: 2199 times
Have the battery professionally tested. It sounds like the battery has a bad cell in it. Once replaced/recharged, have the charging system checked for efficiency. Old battery leads with bad resistance or corroded/loose/broken grounds are also an issue to check.
If the battery continues to drain, check for a parasitic drain (something not switching off when you remove the key and lock the car).
