Another Car, Another Climate Issue. AC This Time. Topic is solved
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
That’s static pressure with the compressor not engaged, simply to verify my sensor is working properly. 400 kPa equates to ~58psi, which is what my gauge was showing, so it seems to be working. I can’t get the compressor to engage at all
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Has thanked: 1609 times
Been thanked: 4064 times
But it still engages briefly when you first command it, then drops out?
V50M66
Post by V50M66 »
abscate wrote: 11 Jun 2025, 02:49 But it still engages briefly when you first command it, then drops out?
No, that was only the first time, when first filling the system. It refuses to engage at all now.
If you put 12v right onto the clutch wire does it pull in?
V50M66
Post by V50M66 »
abscate wrote: 11 Jun 2025, 15:55 If you put 12v right onto the clutch wire does it pull in?
Yeah. Also engages if I jump the relay pins in the fuse box. And engages during the relay test with the app posted above. It just doesn't want to work when it should under normal operation - it's not activating the relay
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
V50M66 wrote: 11 Jun 2025, 18:40
If I had to guess it's going to be a sensor issue where it thinks the pressure is too high or low in the system somewhere then. Have you tried a different CCM unit for giggles?
Scratch that, you said MCC. Darn it. Still say I'd check the pressures reporting. That sounds a bit low at rest to me, but I haven't checked mine recently.
V50M66
Post by V50M66 »
wizechatmgr wrote: 11 Jun 2025, 18:55
Yep, tried a new MCC module with no changes unfortunately.
There's only 2 sensors in this system:
The high-pressure cutoff switch is a binary pressure switch that either allows or disallows current flow based on pressure. I've tried bypassing it (jumpering the pins) and replacing it, and all electrical measurements at both the sensor and the wiring are what they should be per VIDA, so that's not the problem.
The only other sensor is the low pressure sensor, which senses actual system pressure and reports it to the ECU. This one is reading within 10% of the crappy analog gauge attached to my AC charge hose, so I don't think this is the issue either, but I'm not sure what else could be the problem here.
So everything works up to the 4/46 ( that’s the ECU isn’t it) which isn’t commanding compressor on.
Fire up VOL FCR and check for MCC codes , there’s probably something stuck in the baffles
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
The Volvo own literature talks of 70 series code reading through its led on REC button and not anything of reader device for MCC.
Press REC button within 2 seconds after turning Ignition on > release and press twice the button > led will start flashing if any codes.
Removing codes is similar but pressing four times.
V50M66 wrote: 11 Jun 2025, 20:19
Other way around I think.
The low pressure switch is a binary 1/0
The high pressure switch or pressostat supplies a voltage proportional to high side pressure
