2001 V70 T5
I am having some issues with my camshaft timing. I believe the gear for my intake cam was put on incorrectly and they didn’t line the mark up where it was supposed to be after the cam seal replacement. It was running rough at idle and I noticed the timing marks were off. Now they are correct and this is what I hear when I crank it over. Any way to figure out how to time it properly without the cam marks in the correct spot?
Cam timing issues 01 V70 T5
DarkSoul2457
- Year and Model: 2001 V70 T5
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
That is the sound of no compression. You either destroyed your engine and bent some valves or the timing is wrong in just the right way to prevent this.
How did you deduce the timing was off?
DarkSoul2457
dikidera wrote: 13 Jun 2025, 09:08 That is the sound of no compression. You either destroyed your engine and bent some valves or the timing is wrong in just the right way to prevent this.
It ran fine before the cam seal was replaced and after that it was running rough at idle. Took a look at the cams and saw the marks were lined up and after lining them up it started doing that
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
i had to think about that ,dikidera wrote: 13 Jun 2025, 11:43 I think he is confusing the exhaust VVT's forward position when the engine was running and then shut off, in relation to the intake.
the marks are always synced to each other whether the engine is on or off,
the camshaft shifts but not the sprockets.
i feel it was a mistake to adjust the cam sprockets without aligning and locking the cam shafts with the proper tool first.
then loosen the vvt bolt to allow safe vvt hub adjustment.
it should have gone back top the shop, he bought it now.
if he adjusted it more than 4 teeth it probably crashed the head.
- 2070 Views
Last post by wizechatmgr
- 1406 Views
Last post by SomeYahoo
- 1516 Views
Last post by iRenaissanceMan
- 19 Replies
- 5523 Views
- 23 Replies
- 2623 Views
