Hey all,
Done my timing belt and water pump, and it went almost fantastically. The car runs great, timing is proper and it wasn't at all as difficult as I expected. However, the car is leaking from the water pump. When I took off the old pump that was 10+ years old, it had that black gasket which is the subject of many of RobertDIY's water pump complaints. Obviously, I thought I had scraped it off but with the leak I must have missed a spot, which doesn't shock me because what was on there seemed to be stuck on there like glue. Does anyone have any tips on how to get any remaining gasket off? Should I coat the new gasket with a layer of sealant?
The car it's for is a 2000 S70 GLT SE.
Removing that awful black gasket?
melmaclifeform
- Year and Model: 2000 S70 GLT SE
- Has thanked: 2 times
- Been thanked: 7 times
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- Has thanked: 2215 times
- Been thanked: 1853 times
The opinions will vary as to using sealant or not. When you remove the pump check the sealing area for damage by scoring caused by the previous pump replacement possibly. I only use a very light coat of sealant purely to hold the gasket in place while fitting the water pump. I just put it on the gasket face that faces the engine block.
One thing to check is that you have the correct bolts. If they came with the pump, then in theory I'd hope they are correct. I bought an Aisin (OEM) pump that did not have bolts with it. What I found was the old bolts were too long. The newer Aisin pump has a thinner flange where you bolt it through the bolt holes. The bolts for my old pump were if I recall 25mm? long and the new pump needed shorter ones (possibly 20mm). The 2 holes if I recall to the top right of center do not go all the way through. Also the ones that do are not threaded all the way through. I wrote a note on this in a thread about 2-3 years ago when working on a 96 Volvo 850.
melmaclifeform
Scot, I saw your thread actually before posting my inquiry. I didn't think about checking the length of the bolts, but I did order the bolts from FCP as part of a kit. If they were wrong, I would be shocked. When I pull them back out I'll check.
Do you know if there's a part number difference between the two bolts?
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- Has thanked: 1613 times
- Been thanked: 4078 times
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had the same trouble cleaning off the original water pump gasket on my '97 855. I tried isopropyl alcohol and a plastic scraper, but couldn't get all the gasket material off. I ended up using a steel razor blade to scrape the metal face clean... very carefully. It's a difficult surface to access and you have to be very careful not to score / cut the sealing face if you use something like a razor blade. I took my time and was careful -- worked OK for me.
To install the new pump, I used the same method Scot850 describes above... a thin coat of RTV silicone water pump gasket maker (I used Permatex #22071, a little tube).
melmaclifeform
Abscate, it appears that I did in fact get the right bolts then as that's the part number FCP sent me. I suppose next weekend it will be time to take it back apart and see how badly I cleaned, with more plastic scrapers and some more brake clean.
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
That procedure should work, sometimes carb cleaner can soften the old gack up too. Plastic blades are obviously preferred for the reason stated earlier.melmaclifeform wrote: 21 Jun 2025, 08:09 Abscate, it appears that I did in fact get the right bolts then as that's the part number FCP sent me. I suppose next weekend it will be time to take it back apart and see how badly I cleaned, with more plastic scrapers and some more brake clean.
Robert only uses Blue Box Volvo gaskets for the water pump, installed dry. My guess is he has done it a few more times than most on this Forum.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I use old debit/credit cards coupled with throttle body cleaner for scraping gasket material off of aluminum. You can cut them to get a fresh sharp edge or to make a weird shape.
1999 V70 GLT
1999 V70 GLT
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
Yeah, this is exactly why you should NEVER use any gasket maker (or even an aftermarket/off brand gasket) on the water pump - it doesn't really seal great and leaves a god-awful mess for the next guy (you, in this case). Genuine Volvo gasket only, installed dry. Never had any leaks on the 10+ timing belt/water pump jobs I've done using genuine parts the specified way.
Agreed with the others - some solvent, a stiff plastic scraper, and tons of patience should do the trick. If not, you can very carefully use a razor blade on stubborn bits - just be extra cautious to avoid gouging the mating surface.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
I’ll confess I’ve used Permatex , a very light film on mine. It does clean off with alcohol or brake clean like magic. The key here is a light film, thin enough thst you still see the metal. I should follow Robert-lore, though.
