25-40 liters of trans oil for a flush!! Wow. Normally 10-12 liters has been enough for any of my Volvo transmissions.
- Has thanked: 2200 times
- Has thanked: 987 times
- Been thanked: 1075 times
About June 5 I had a no start condition that final started after giving some throttle. This was on my 2001 V70 T5 with 218,700 miles. I got it home about 4 miles in what must have been limp mode. Poor throttle response. Surging idle. RPM limited to 2000 RPM. I shifted manually to get up to 45 MPH.
I checked codes and had many, including CEM-1A5D Communication with ETM. However, restarts were sometimes good and idle smooth. I checked live data and spark timing, MAF and TPS % all looked OK.
Next day, I restarted and got rough, surging idle that smoothed out after a couple minutes. I restarted and got new codes including ECM-902A Communication module ETM and ECM-903F ETM internal fault. I cleared all codes.
Next day and I started and had rough idle. I checked live data and found TPS (Throttle Position Sensor) was at 0% while RPM was surging around 1000. New Codes were CEM-1A5D Communication with ETM, ECM-904A communication with throttle unit, ECM-903F ETM
internal fault, and misfire codes.
I decided this was consistently pointing to ETM failure although the ETM was replaced in 2019 at 197,000 miles. I ordered the XeModex remanufactured ETM with upgrades. I hoped this was correct because ETM was $643 after core refund of $100.
I installed the reman ETM this week and all is well again. The ETM swap took me about 4 hours. First restart was good with no loose hoses or connections.
I have no complaints about replacing the ETM after about 20,000 miles. I do mostly in town diving so it gets lots of throttle position changes.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Today I got the CEM reboot bug again, car lost all electrical power for a moment and I heard the relays click.
Unfortunately this event somehow decalibrated the DIM, the RPM needle's resting position shifted to 1100rpm even with engine off. How is this possible?
ortho stice
- Year and Model: 2006 XC70
- Been thanked: 5 times
Timing belt, water pump, coolant bottle, accessory belt and tensioner, and a PCV service. I remember doing the timing belt on my '99 V70 in like 1.5 hrs (12 years ago) but this job was much harder. I skinned a lot of knuckles!
I tried to do the PCV without removing the thermostat housing but that was dumb; removing that makes the whole thing easier and I put a replacement on since I had no info on when it was last replaced. I replaced the killer banjo bolt; the replacement from FCP was stamped 2023 which I thought was interesting. The hard plastic line from the banjo bolt to the elbow coming off the oil separator box was so brittle that it immediately snapped. I used some silicon hose I had as a replacement; I figure it should hold up okay. The passages to and from the oil separator were completely clogged with oily carbon debris, so I'm glad I jumped on that.
SacredHeart
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 12 times
- Been thanked: 2 times
Put a little over 6,000 miles on my 2006 S60 since I purchased it in early February so I did my second oil change yesterday and am going to do a drain and fill on the transmission fluid since I have no record the last time or if it was done. I am guessing that it was at some point before the records I have, but it cannot hurt. My only issue is that I need some containers for the spent fluid so I know how much is being taken out and need to put back in. The only empty container I have is a 750ml bottom that my Redemption wheated Bourbon came in. I don't drink milk or 2-liter bottles. I will have to figure that out before I start draining.
I thought that the ETM repair by Xemodex had a lifetime repair if you were the original purchaser of the unit? Is this no longer the case?
My car is fitted with a Xemodex unit, and I started having the occasional issue with it. It was then I found as I did not purchase it all bets were off. Not impressed.
I drain into a cheap, plastic, rectangular dish wash tub that has graduations marked on the side. Purchased from the dollar store. Not great accuracy, but OK and large enough to catch the fluid drained.SacredHeart wrote: 28 Jun 2025, 08:17 Put a little over 6,000 miles on my 2006 S60 since I purchased it in early February so I did my second oil change yesterday and am going to do a drain and fill on the transmission fluid since I have no record the last time or if it was done. I am guessing that it was at some point before the records I have, but it cannot hurt. My only issue is that I need some containers for the spent fluid so I know how much is being taken out and need to put back in. The only empty container I have is a 750ml bottom that my Redemption wheated Bourbon came in. I don't drink milk or 2-liter bottles. I will have to figure that out before I start draining.
crasbe
- Year and Model: 02 S60, 98 V70 (EV)
- Has thanked: 33 times
- Been thanked: 82 times
After 2.5 years or 80,000km my rear brakes were due. I think I got my money's worth out of the brake pads
Usually I don't run them THAT far down but I simply forgot that I wanted to replace them when I put the winter wheels on, so it was a bit of a surprise in the spring(ish)
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables
