Oil found in spark plugs. What to do? 2009 XC70 T6
slovely20010
- Year and Model: 2009 Volvo XC70
I had a check engine light for a misfire in cylinders 3 and 5. I went to change the spark plugs and discovered that the cylinder 5 plug was a bit wet with oil and the cylinder 3 plug had a decent bit of oil pooled. Since this vehicle doesn’t have a traditional valve cover gasket, what could be the issue? I checked the other spark plugs and they were dry. Is this something that can be repaired by taking the valve cover off or is there a deeper issue? If there is a part I can purchase a link or part number would be appreciated. Thanks!
- 1907 Views
Last post by pgill
- 3321 Views
Last post by ndphotonl
- 16 Replies
- 4454 Views
Last post by shiloh51933
- 14 Replies
- 2410 Views
Last post by mrbrian200
- 3469 Views
Last post by StickyPocket
