Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
I just cleaned up after being stymied 90% through an alternator replacement.
I have the alternator's bolts out but can't budge the lower AC compressor bolts.
Tomorrow...... This is a 2007 V70 base.
Has thanked: 1611 times
Been thanked: 4072 times
The fore aft running M6 bolts ? Those can lock up indeed.
Good new 6 point 10mm socket and breaker.
crasbe wrote: 29 Jun 2025, 16:22 After 2.5 years or 80,000km my rear brakes were due. I think I got my money's worth out of the brake pads :shock: :lol:
Usually I don't run them THAT far down but I simply forgot that I wanted to replace them when I put the winter wheels on, so it was a bit of a surprise in the spring(ish) :shock:
Are you finished with those brake pads? Trying to get them before Niel ….
crasbe
Year and Model: 02 S60, 98 V70 (EV)
Has thanked: 33 times
Been thanked: 82 times
Post by crasbe »
abscate wrote: 30 Jun 2025, 03:31 Are you finished with those brake pads? Trying to get them before Niel ….
I'm not sure I get that reference?
But yes, they are already in the scrap bin.
Check out my 3D Printed Parts for Volvo P2 and P80 on Printables :D
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
BlackBart wrote: 29 Jun 2025, 15:54 Yow! Rusted?
It looks like a combination of rust and metal fatigue. I wonder if I can replace it without fully removing the subframe but only lowering it. And whether I should unbolt the steering rack or just the bolt from the steering column.
The engine will be held by a hoist.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
All of that……
…needs to go under my car tomorrow…somehow…
dikidera
Post by dikidera »
I think part of the reason my sway bar snapped was that I might have overtightened it when I was replacing the transmission. I had it removed to replace bushings only to find them welded shut. So I gave up and reinstalled it....but I may have torqued it down too much. Despite the end links being disconnected the sway bar itself felt stiff, with almost no movement up or down.
This one might have been on me.
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
Planned on pulling a junk yard power steering pump to see if mine is too tough. Friend complained it was too tough which stopped the deal. If it gets fixed then they are open to the car. Otherwise she goes on the facebook marketplace. My indy said he can safety the car, and it does not need anything major to safety (one endlink). Will find time to sell the car in July at some point.
2008 S60 2.5T Auto (Sold)
Has thanked: 2207 times
Been thanked: 1852 times
Darn, Abscate beat me too those brake pads! They could have gone on a few more miles yet! :roll: :lol:
For those newer members this is a long standing joke between me and Abscate. Being Scottish I can't think why....... :D
BlackBart
Post by BlackBart »
Well I’m cheap too….but not Scottish (I think).
Today I………
used excessive leverage…..
