95 NA engine swap
fredt2
Year and Model: 850 GLT 1995
Has thanked: 2 times
Been thanked: 7 times
Post by fredt2 »
Hello my dudes,
As per previous post, I had a back and forth with my 95 GLT, in which I ultimately decided to replace it's engine. Already found a guy with the exact same engine 20mi from here, only 40k miles on the clock.
So, my question is, is there a way to pull the engine without pulling the tranny together? Anyone already done it? I really don't want to go through the trouble of disassembling the entire front axle to replace the engine
Been thanked: 4065 times
You can get an automatic car engine out the top leaving the transmission in.
You can’t do it with a manual
fredt2
Post by fredt2 »
Yeah, it's and auto, forgot to tell that part, so i just gotta unbolt the flywheel and the rest of the tranny and pull it out?
You need to systematically follow a procedure , not just try to figure it out as you go, for success.
fredt2
Post by fredt2 »
Yes, I will follow the procedure on the Haynes manual, I asked because the procedure on the manual describes the removal with the tranny attached, so i had this doubt if I could pull it apart, apparently I'll just follow the tranny removal procedure separately and just leave it in the car
