2004 XC70 no start - faulty fuel pump and/or electrical connections? Topic is solved
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
Re: 2004 XC70 no start - faulty fuel pump and/or electrical connections?
Yes. More than one year later and the fuel pump has been working fine. I was concerned that I might have failed to secure the driver-side level sensor to it's fitting during reinstallation. Decided it's not worth dissassembling to check and so far no problems.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
awizarddresden
- Year and Model: 04 xc70
- Been thanked: 3 times
You're an absolute life saver. Gonna grab a fuel pump and all the stuff to do one!
- Has thanked: 1505 times
- Been thanked: 3818 times
Thanks for closing loop on this enotslim. That v70 you donated is still tooling around upstate nY doing social good.
Appreciate it, and the work you do in these troubled times
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 53 times
- Been thanked: 62 times
abscate wrote: ↑03 Mar 2023, 03:59 Don’t guess in that plug pins there please. You are applying current to a pump immersed in gasoline.
--end quote --- I deleted the end quote HTML on accident...
Current to the fuel pump doesn't cause any problems as long as you aren't adding oxygen to the inside of the fuel tank...
[Car companies did a lot of testing to validate the safety of fuel pumps inside the fuel tank and some car companies add a flame arrestor to the inside the filler pipe because of the increased flammability of ethanol E85 compared to regular gasoline. The printed ink on the fuel height gauge contact board will short out if fuel pump power is run across it.]
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
true.
I had a bad habit of running around on 1/4 tank in my 740.
the pump died, I pulled it and the elecs were toasted, brushes melted and burned to a crisp.
I yanked the pump from its housing, made in S,Korea, I bought another from autozone for $55.
awizarddresden
An update on my pump replacement. The replacement went smoothly. Still the same issues though. If I let the car sit for a day, the first start the car will shudder and die. If I immediately try to start again It fires right up and runs smoothly.
At this point I'm not sure what is causing the issues. I know I need to do the pcv still. But I don't think it would cause this. I've cleaned but not replaced the maf. And done a visual and tactile check of all the vacuum lines as well.
How much money and time is work dumping into a 220k mile Volvo that I got for 2 grand? I love this car but I don't know if I'm willing to let it control my life lol
- 639 Views
Last post by Chriskelly1962
- 4883 Views
Last post by misha
