Vida CEM swapping
oeben
Year and Model: 1982 242
Post by oeben »
The one I have with 30855 is also 0 in the key bytes, the one with 30835 is the damaged one from the car I was trying to salvage, this one however states it needs a password to read in JTAG.
I will try USB to serial on the 30835, maybe it works.
duzi
Year and Model: S60
Has thanked: 18 times
Been thanked: 5 times
Post by duzi »
oeben wrote: 29 Jun 2025, 09:18
M32C / M30835FJVGP.
implemented long ago transfer all data from 835 to 855.
porcupine7655
Year and Model: 2006
Been thanked: 20 times
Post by porcupine7655 »
oeben wrote: 29 Jun 2025, 11:18 The one I have with 30855 is also 0 in the key bytes, the one with 30835 is the damaged one from the car I was trying to salvage, this one however states it needs a password to read in JTAG.
I think it is good to do it on a controlled way to show in what stage it fails.
If you get any readable string from version command, such as VER.1.16, you know that your wiring is correct. To be sure, test several times or even better in a loop. It can still be so that the cpu restart of any reason at some point after.
After the login is sent, it can be seen in the status bits if it is OK or not. Don't remember what bits to look for. In my example I print out status several times, before and after login.
In this way we can see what the problem is.
I'm also somewhat confused what interface was used when you say JTAG. As far as I have been able to find out there is no debug interface on this chip. How was this JTAG interface connected? What pins was used?
oeben
Post by oeben »
I was mistaken, I thought it was JTAG but it's SPI.
That's why it will not read without the PIN, it would be possible to retreive the PIN if it was communicating (in car with the equipment I have available).
I will have to look into it deeper next week, I tried repairing the PCB by fixing burnt traces and cleaning all corrosion, but still no comms.
Will try with the program you attached to see what happens.
oscilloscope
Year and Model: 2005
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
I have been looking for a complete wiring diag for a late 2010 v50 for a sid807evo and the p2 cem so I can do some bench testing for synchronisation procedures over obd, or obtaining the eeprom & flash from the sid807, I found this site (below) and got a strange feeling it was to good to be true has anyone tried viewing the pdfs for the wiring diags ? As they do not open within the browser you have to click the pdf button which I have not done.
https://volvodiag.com/ewd-online-eng/
EDIT :
never mind it looks like it was loading differently on my mobile compared too when i loaded it on my laptop that site above looks like a genuine volvo site.
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
Anyone can help with eeprom decode algo? Two days, and 61bytes decrypted at all......
Code: Select all
#!/usr/bin/env python3
def hex_to_bytes(hex_string):
    return bytes.fromhex(hex_string.replace(" ", ""))
KEY = "96 BB 1D 13 B3 07 D2 39 FC 20 26 D8 30 8D 31 3F 4B EB 3C D4 2E C3 76 5D 20 BC 31 81 77 19 EF 3E 27 0C 69 7E 1B 1C 15 AE 66 BE 1F 56 3B B1 F4 6C DC 98 9B 18 74 E8 44 EA 7F F4 AE 6A 25"
key_bytes = hex_to_bytes(KEY)
def get_subtract_value(group):
    if group == 0:
        return 0
    elif group == 1:
        return 1
    elif group == 2:
        return 2
    elif group == 3:
        return 3
    elif group == 4:
        return 4
    elif group == 5:
        return 5
    else:
        return group
def decrypt_file(input_file, output_file, key_bytes):
    key_len = len(key_bytes)
    with open(input_file, 'rb') as f:
        encrypted_bytes = f.read()
    decrypted_bytes = bytearray()
    with open('decrypt_log.txt', 'w') as log:
        for i in range(len(encrypted_bytes)):
            group = i // 61
            key_index = i % key_len
            subtract = get_subtract_value(group)
            temp_byte = encrypted_bytes[i] ^ key_bytes[key_index]
            decrypted_byte = (temp_byte - subtract) & 0xFF
            decrypted_bytes.append(decrypted_byte)
            log.write(f'Byte {i:4d} (group {group:2d}): {encrypted_bytes[i]:02X} ^ {key_bytes[key_index]:02X} = {temp_byte:02X} - {subtract} = {decrypted_byte:02X}\n')
    with open(output_file, 'wb') as f:
        f.write(decrypted_bytes)
if __name__ == "__main__":
    input_file = "crypted.bin"
    output_file = "decrypted.bin"
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
What is it from?
Treur
Post by Treur »
dikidera wrote: 09 Jul 2025, 12:55 What is it from?
Hand made)))
WhizzMan
Year and Model: 2001 XC70
Post by WhizzMan »
Treur wrote: 09 Jul 2025, 13:06
Hand made)))
Not enough information.
What device are you trying to decypher? Please provide all binaries you have. How did you get a 61 byte key? What cypher is being used? It doesn't make sense you have a 61 byte key, it's just an odd number.
If the binary you are trying to decypher is more than 61 bytes, you need to loop over it somehow, if the key is only 61 bytes. This is why it is important to know what cypher is being used.
Dudde
Year and Model: 2005 V70 and more
Has thanked: 17 times
Been thanked: 17 times
Post by Dudde »
Treur wrote: 09 Jul 2025, 10:35 Anyone can help with eeprom decode algo? Two days, and 61bytes decrypted at all......
Code: Select all
    if group == 0:
        return 0
    elif group == 1:
        return 1
    elif group == 2:
        return 2
    elif group == 3:
        return 3
    elif group == 4:
        return 4
    elif group == 5:
        return 5
    else:
        return group
            group = i // 61
If you are trying to decrypt CEM L eeprom i have solution
