Has thanked: 1850 times
Been thanked: 1712 times
For a P2, the axle bolt for the CV axle is 35Nm + 90 degrees.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Now…..did I torque this already? No idea. I should put a little yellow paint pen line on critical bolts after they’re torqued.
Reminds me - there was an obsessive guy in Germany on the Audi forum who built a high performance A4 Avant from a bare body shell. He built it like an airplane, with safety wire on the hardware and little blue paint lines across the heads or nuts onto the sheet metal so you could visually check to see if something was backing out.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Kid called with check engine light on the 02 S60 2.4t. Was due for oil change so did that and scanned to find P0496 EVAP code.
Sure enough the EVAP hoses to the driver side of engine looked to be what the Brits would call manky or perished…not sure. A trip to the farm supply store for $5 worth of 3/8” fuel line fixed it all up. Of course in peeling the hoses off the check valve I forgot which way was which—50/50 chance, I think I got lucky and assembled it correctly!
08 C702.5T (sold)
The non-Swedes:
I've taken to using a paint marker as my memory is not what it used to be. Also I am now helping others to learn so get distracted so it is easy to forget and miss torquing something. I also do this for angle tightening by marking on the bolt/nut I am tightening and the area around it to give the approximate angle.
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 175 times
Post by dikidera »
Oh yeah definitely. I replaced my entire transmission, I torqued everything down BUT one of the wheels. I was doing 50mph and was wondering what that noise was....it was the wheel, the bolts were only finger tight and already ready to back out.
Has thanked: 1506 times
Been thanked: 3818 times
I think it’s universal on Volvo check valves that white is high pressure and black side is lower or vacuum pressure
So blackside should be plumbed closer to the brake booster or to the vacuum source
For a turbo, the snorkel is alway a vacuum source but the manifold is either a vacuum source or a pressure source, so plumb the check valve to the manifold , black closest
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
There should be a vacuum diagram under your hood. The check valves have an arrow indicating the direction of flow.
04s60 2.4
04xc70 2.5t
SteveOV70
Year and Model: 2004 V70
Has thanked: 3 times
Post by SteveOV70 »
Hey krons ya that’s what I was doing, after all the research Iv done about the PvC system I did decided that if I’m doing the job, better do it right and check the whole system out. I did do the O-Rings, along with the sump ring and the cooler rings, pretty much everything that the entire job would entail. I got the pan and everything back on last night, and tonight now is the start of putting the new separator back in then the rest!!
BlackBart
Post by BlackBart »
Mr turbo looking up from below …..
BlackBart
Post by BlackBart »
Shiny new (THICK) aluminum skid plate. My plastic tray was long gone, so I put this on.
