We don't use the A/C all that much - I roll down the windows. Now that it's scorch season I've caved and glad to have it.
When I flipped it on, there was a rumble you could hear and feel. Not engine noise. I turned it off and it disappeared. I went ahead and ran it on the highway and it seemed to quiet down and smooth out.
Is this the compressor, from not enough use?
A/C rumble / vibration after little use.
- Has thanked: 2200 times
Perhaps the bearings got a little dry from lack of use, and now using it, it has relubed itself?
Bit like the gasoline smell on our 06 XC70, there for one day then disappeared. Have to now wait and see if it reappears.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Could also be the cooling fan, that comes on with the A/C.
2003 XC 70 (sold)
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Different blower than the heat fan, or is it all one HVAC system? Because we have the squealing fan when it’s very cold, worth changing. Maybe I should take a stethoscope to the compressor at idle and try to trace it.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I think he's talking about the rad fan BB.
My engine struggles when the compressor is running, almost like it's going to misfire, oh well.. lol
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
Oh, right. I read a thread here about the blower fan getting gummed up.
Tested some this morning. Blower fan pushing nice cool air out. When A/C kicks on there’s a light clunk from sort of low RF area where the compressor is, and some noise and vibration. Stops when you cut the A/C. But I think much quieter than the other day when I first used it. We’ll drive it a bit and listen.
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
My guess: since you haven't used it in a long time, most likely rust formed on clutch and pulley. It is possible that it formed in such amounts that when ac clutch engages it causes vibration to entire serpentine belt system. Since each time the ac clutch cycles some of this rust is falling off, you experiencing less issues.
So a bit like rusty brake rotors after a car has been sitting, and then them cleaning off with use?
Sounds like a grumbly compressor. It will last 3.7 more seasons until it needs replacement
