0930-1130 report today
New Orings and attached Dryer and suction hose to compressor, with new hardware
Trick - take the 27 mm union nut to tightness (cant rotate hose) then back off one 1/2 of a flat so you can nip it tight when done. Its not a flare, the o-ring does the seal work
Installed high pressure side, new orings, new bolt
Dont forget the plate to hold the dryer mount
Dont forget to put on \the forward plate on the evap hoses before connecting the hard lines, then add the two plastic keeper washers, teeth facing forward too.
you can bend the evap lines 5-6 mm to get a straight push on the hard line to seal it up.
1999 s70 Evita AC evap replacement (July 2025) [12 hours, $150 parts] Topic is solved
- Been thanked: 4068 times
Pumped down and tested System. Home stretch!!
Pizza t 1800, 1900 Zoom call
In between, got dash in.
Spotted a Flicker
Admired garage construction across street
Took the 18 year old Apexpredator to the vet
Documented the torx 25 head, 19 mm thread screw that seals the heater core to lower pipes on p80s
Volvo Spoiler Screw - Genuine Volvo 986200
Missing m6 nut upper left Acc pedal
Missing screw heater firewall bracket
M6 screw on ac bulkhead seal
Gear shift plunger check
Spotted a Flicker
- Has thanked: 987 times
- Been thanked: 1075 times
You are an inspiration to DIY everywhere!
2 hours this morning electrical connections, securing stuff, coolant connections, and got motor running.
Finishing inside as I charged AC, heard the compressor cycling, then steady on.
Acheived 40F delta (RECIRC, fan speed 3, 2000 rpm) and 35F delta on outside air ambient 86F
It felt darn good.
It felt darn good.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Nice job! I want some of your energy
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
More job tips
Silicone spray the ECU cooling air pipe on both parts before install, much easier. Install rear part first , the the front part.
I forgot to nip the final torque on the dryer so had to pull the m6 bolt to raise the dryer enough
A 27 mm crows foot or 1 1/16” Imperial would work there but clearance is tight. Maybe from underneath?
Next time will remove ETM gas pedal and complete bulkhead heater pipe assembly and install after HVAC replacement. I think it’s way too easy to put torque on this pipes and break the bulkhead fitting, a $150 event
- Has thanked: 2202 times
Again, well done for completing this major task!
Are you having your house or garage extended? Hopefully the garage!!
Across the street.
This is impressive.
Start car, back into street.
50myards to first stop sign
Turn right
150 yards to next stop sign
Cool air is pouring from vents.
This is impressive.
Turn right
One last gaffe.
I tucked the two antenna wires into the climate unit and then trapped them when I put the dash back in. Luckily just had to loosen a couple of screws and ease dash back 1 cm to free them up
- 28 Replies
- 4863 Views
- 10 Replies
- 694 Views
- 15 Replies
- 6516 Views
Last post by wizechatmgr
- 1033 Views
- 51 Replies
- 5293 Views
