Vida CEM swapping
Yariy
Year and Model: XC90
Has thanked: 16 times
Been thanked: 10 times
Post by Yariy »
I agree, there are very few cars with the CEMB unit left. We do not take these cars for diagnostics because of their age. But I was interested in reverse engineering and the lack of a tool for this block, so I decided to try my hand at it.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Curiosity drives the progress.
Yariy
Post by Yariy »
WhizzMan wrote: 18 Jul 2025, 06:49
Treur wrote: 18 Jul 2025, 06:33
The problem is that Io-terminal and others cannot load SBL with a pin other than FF.
So even if you know the PIN, you cannot modify the SBL to work with a different PIN?
Would below scenario work? Is it even useful or would just using other method be just as fast/complex?
1. Read the PIN via other method
2. "store" the original PIN
3. write just the pin to FF (let all other data remain)
4. Load SBL, read entire 512 kB.
5. write original PIN back.
Yes it will work
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
Yariy wrote: 18 Jul 2025, 08:17
Treur wrote: 18 Jul 2025, 06:26
Yariy wrote: 17 Jul 2025, 14:32 And that's why I'm leaning towards SBL for CEMB, because for example, in diagnostic mode, you can read the entire flash (512Kbytes), but it takes at least 20 minutes, and reading from the address in programm mode takes many times more. My test SBL reads the flash in 1 minute and 20 seconds, but so far without any checksums, etc. Well, it doesn't matter yet.
Так бесполезно читать в диагностической сессии, ну прочитали, а записать всё равно в ней не можем. Вот если мы можем переписать кусок с пином/пропатчить основную программу и PBL, то был бы смысл. Я не особо даже рассматриваю уже этот металлолом ибо тачки на них уже в стадии вымирания.
По части терминала - они далеко не всё вывесили на сайте. Я уже поимел их SBL, но CEM его принимает только при пин FF, и я честно то говоря не очень понимаю мышление шведов - мы пишем только новый блок. Тут рождается логичный вопрос - приехал к дилеру клиент на скажем дооснащение ииии????
Honestly, I haven't figured out what the SBL download function is used for in CEMB. Maybe a dump of a brand new CEMB will clarify things. The configuration lies in an unprotected area and you can change it knowing the current Pin code and not necessarily FF. The protected area contains the pin code, keys, synchronization, etc.
I don't get it either. Especially considering all the references in Vida about software numbers for downloading
Yariy
Post by Yariy »
Treur wrote: 18 Jul 2025, 08:43
In Vida, I saw the vbf number for download only when replacing with a new block. Are there vbf CEMB numbers available for download, for example, during retrofitting?
Yariy
Post by Yariy »
It is interesting to take a look at SBL ioterminal. I am most interested in whether the PBL recording function is included in it. At the hardware level, I have not yet found out if it is possible to remove the write lock on the loader area.
Treur
Post by Treur »
Yariy wrote: 18 Jul 2025, 11:03
Do you have a Telegram?
Yariy
Post by Yariy »
Treur wrote: 18 Jul 2025, 11:31
See the mailbox
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Please try the J2534 tool, for now works on Hispeed bus(so do not choose anything else), be sure to click 29 bit extended ID. Platform also does nothing useful quite yet. Sources in the near future when everything works correctly.
I am happy with the way the monitor works, please test with Mongoose and if someone can with DiCE.
j2534.7z
(8.4 MiB) Downloaded 132 times
bosse
Year and Model: V50 -11
Has thanked: 9 times
Post by bosse »
Waiting for page 400...
Follow from start 😀👍
