What an exciting project!
Please keep us posted.
Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
LongNoseElk
- Year and Model: 2006 V70
- Has thanked: 123 times
- Been thanked: 24 times
melmaclifeform
- Year and Model: 2000 S70 GLT SE
- Has thanked: 2 times
- Been thanked: 7 times
FCP should have most everything the car needs to get running. Your only real issues is the rear AWD suspension and brake parts IIRC.
2000 S70 GLT SE
1997 Volvo 850 T5
2011 Volkswagen Jetta SE
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Sounds like you have a good grip on the basic stuff.
'99 was a transition year - abscate has a thread here somewhere, search for 'bastard' - so some parts may be tricky to source.
Depending on the working conditions dropping the rear subframe for the pump may be quite the chore, and since the car is a bit of a question mark consider the idea of cutting an access hole in the floor. The resulting repair is completely hidden by the rear seat back. Robert has used the method several times and one of his vids shows details on the right spot. That would obviously be the fastest way to get it running.
There are a couple of R specific things that might need attention once it fires, so keep us in the loop.
And of course nobody will believe the story until we see the pictures.
melmaclifeform
Signal red should shine up pretty well, too.
2000 S70 GLT SE
1997 Volvo 850 T5
1999 Mazda Miata
1997 Volvo 850 T5
1999 Mazda Miata
melmaclifeform
chaosrob
- Year and Model: 1999 v70R
- Has thanked: 37 times
- Been thanked: 15 times
Not much of a red fan myself honestly but it was what was available to me
melmaclifeform wrote: ↑23 Jul 2025, 18:13It may well be. I mix up all the red names constantly, because I only concern myself with beige and white cars.
