Not too hateful at all!
That mold will clean up nicely and thst leather will shine with some CONNOLLY’s applied
The back axle drop and suspension stuff is covered in a heavy thread by our friend scot850 up in Alberta. I’ll link to that thread
Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
- Been thanked: 4064 times
- Has thanked: 2197 times
- Been thanked: 1850 times
I'm curious. Being an R, I would have expected a duel muffler at the rear, not a single one. Was 2000 the only year with dual mufflers?
We would have to look at the Vin# for sure, as I have never seen a R in that Red. The only red I have seen is the dark metallic red. So I went looking and Googled 1999 V70R and found this car:
https://bringatrailer.com/listing/1999-volvo-v70r-5/
It has only a single exhaust tip like the V70XC on the RHS at the rear. Even looks like the same wheels.
It will be an interesting challenge.
Just about an hour ago my ex-Volvo mechanic friend sent me a link to FBM for a 2000 V70 needing rescued. Never again! Doesn't help it is missing the driveshaft and may have other AWD issues including the trans/angle gear. Prop-shaft is out so the bigger issue is does it have the prop-shaft center bearing support. That is beyond unicorn status now.
Doesn't help it is also black (I hate black cars), and has 'some' hail damage.
Edit. Rechecked the ad on my PC not the cellphone. Discovered it is a Dark Blue. They were sold in Nautic Blue in 2000, but this does not look like Nautic Blue. Also mileage is 200000+ miles.
chaosrob
- Year and Model: 1999 v70R
- Has thanked: 37 times
- Been thanked: 15 times
It does indeed come back as an R in that color by vin: YV1LV62D4X2587247
scot850 wrote: 23 Jul 2025, 23:34 I'm curious. Being an R, I would have expected a duel muffler at the rear, not a single one. Was 2000 the only year with dual mufflers?
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I had never noticed before that, on the AWD model, the gas tank fill door is on the same side of the car as the exhaust pipe
I kind of thought that was a no no..... At least it is for other cars.
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Who would just leave a decent R wagon out in a field? Unless it quit and they didn't have the money to pay to fix it.
I know a guy in ALberta who has thought about driving his over a cliff several times...
Link to the back axle MegaPost....
Mine is here...the Kat
viewtopic.php?t=95586&hilit=resurrection+kat
Neils is here - and its more detailed than mine
viewtopic.php?f=1&t=69287
jimmy57 post on fuel pump change here
viewtopic.php?t=48133
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I have a bulletin for you: that won't pass a "beat" on here. It looks better than 75% of my fleet just sitting on the trailer.chaosrob wrote: 23 Jul 2025, 17:46 Just to give you an idea of how beat this thing is here is a walk around video on the trailer at time of pickup
Denatured 91% alcohol will knock that mold out instantly.
Those seats look to be right nice. There is s specific cleaner recommended for the fuzzy part in the middle.
P80 AWD and Rs have that wierd dual exhaust with a single tail pipe. Pep boys actually has a decent aftermarket one. It loops over the left axle to the left muffler, then has a crossover to the right muffler to the tailpipe. Putting the tailpipe on the passenger side evens out thrust on the track when there is no passenger in the car, for a 3 HP gain, per bdub.
Ok, I made that up.
Added context to title, because we do that here.
Ok, I made that up.
chaosrob
Here is a picture from before being drug out of its hole
It's a little thing but managed to replace the rear lift gate shocks so the gate would quit hitting my head when getting in the back. Should make cleaning it up easier. Lots of mud dauber nests in the back and under the trim I needed to remove for the shocks. There is a fair amount of rattling under the rear trim on the gate so I imagine it is full too. So far zero mouse droppings inside, there were plenty under the hood but not in the car itself....so far .Does that carpeted trim on the gate just pop off or are there hidden screws? TIA
chaosrob
My family thinks I am crazy and do not understand my fascination with this car at all. I thought it looked pretty exceptional for sitting in the muck since 2013. It certainly has its challenges though so I am not blinded by the work it will take to bring it back.
foggydogg wrote: 24 Jul 2025, 21:38I have a bulletin for you: that won't pass a "beat" on here. It looks better than 75% of my fleet just sitting on the trailer.chaosrob wrote: 23 Jul 2025, 17:46 Just to give you an idea of how beat this thing is here is a walk around video on the trailer at time of pickup
