bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I think that's how it goes, and it's aggravated by a hot lean mixture, which just torches the valve. I agree with the theory on oil reside retaining heat too, since that seems to be a common theme on these cars when they burn valves.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
From what I know watching too much of a certain kind of video youtube barely tolerates
Hot, high pressure gasses have an erosion effect, and any type of debris in the valve face would cause a break in the seal where combustion gasses would leak through. These gasses would slightly wear away at the metal as the combustion byproducts act like microscopic abrasives. The heat escaping into areas with significantly more oxygen than the cylinder would also make the metals much more reactive, not quite actual combustion, but scorching some off like the oxycetylene torch mentioned.
Now that could be barely a scratch the first time, but now it has an imperfect seal, and the next combustion finds that exact same spot over and over until you burn through the valve entirely.
I agree with the others that the valve stem seal is the root cause but I don't think it's the residue holding heat
I could very well be wrong haha
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Seems to me this is like the erosion of early rocket nozzles that were not of good enough material.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So here's something else to chew on. My procedure for cleaning the head is copious amounts of throttle body cleaner (4 cans on this head), followed by a soak in hot water with detergent. Then another shot of throttle cleaner if needed, and finally WD40. When I lifted the head up to take it for its bath, I noticed this left behind. Yep. A valve seal just fell off of the guide. I don't think they're supposed to do that :shock:
So at least in this case, faulty seals were the culprit.
1999 V70 GLT
Has thanked: 2211 times
Been thanked: 1852 times
So is that where the expression, " My Volvo goes like a rocket!" comes from? :roll:
:lol: :lol:
Neil
Sveedy
Post by Sveedy »
And, yes. That tray was clean when I started.
1999 V70 GLT
DragosGD
Year and Model: S70 T5 - 1998
Has thanked: 9 times
Been thanked: 6 times
Post by DragosGD »
I installed and painted the reversing sensors on the rear bumper of my S70. The original VOLVO kit was bought many years ago, so it's a great achievement :)
Sveedy
Post by Sveedy »
Windows decided to stop working today. Took the master switch apart, and yuck...
Cleaned, reinstalled and windows work again, though one of the rears seems a little finicky.
1999 V70 GLT
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Found the pieces to the cargo area shade so I can epoxy them back together in the days to come.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 71 times
Post by jsrnsis »
I got the blue V70XC started after waffling on it for a year....and it's still making a horrific tapping sound, same as it was when I took the head off. I believed that was due to the RTV on the exhaust gaskets blowing out from a backfire, but maybe this car has a cracked exhaust manifold? Exhaust is separated in the middle behind the cat, but it seems to be coming from the engine bay and exhaust manifold area. Would have been nice to catch while the head was off, but I'm going to hook up the smoke machine when I get home.
1998 V70XC black 215xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 125xxx
