Compatible Rear Driveshafts for 1997-2000 V70 awd
Thanks for the Data lift!
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
In plain text as follows. Note this is for V70, and the VIN splits are different for S70.
Early 98 (flat flanges) is up to chassis no 482681
Chassis 482682 up to 630091 take the late 98 - 99 driveshaft
630092 and up take the 2000 driveshaft
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Final piece of data needed. Flange sizes and lengths of shafts and viscous couplers for each of these three options
- V50M66
Both the ‘99 and ‘00 variants use the same visco unit - just the early ‘98 unit is different, and is easily identifiable by its flat flanges (as opposed to cupped on later variants).abscate wrote: 29 Jul 2025, 18:10 Final piece of data needed. Flange sizes and lengths of shafts and viscous couplers for each of these three options
And the body is a bit longer, so the most forward arm that takes the last bolt vertical into the frame is shorter.V50M66 wrote: 30 Jul 2025, 07:18Both the ‘99 and ‘00 variants use the same visco unit - just the early ‘98 unit is different, and is easily identifiable by its flat flanges (as opposed to cupped on later variants).abscate wrote: 29 Jul 2025, 18:10 Final piece of data needed. Flange sizes and lengths of shafts and viscous couplers for each of these three options
(Insert picture here)
- 1284 Views
- 951 Views
Last post by xHeart
- 532 Views
- 387 Views
- 887 Views
Last post by precopster
