Recently my beloved pre facelift 850 was t- boned by a pickup truck. Thankfully nobody was hurt, it actually took the impact very well. I just bought a 96 wagon that's pretty nice overall. I'm wondering if anyone here knows if the pre facelift fenders and doors will fit on the post facelift. I can see the trim is different but I'm hoping that can be swapped, I'm not sure if they attach any differently though.
I just can't decide if it’s worth it to go and pull the fender and doors off my old car vs just touching up a few spots that bother me on the new one. I would also have to swap the door cards as the new one has the charcoal interior and my old one had tan.
Pre vs post facelift body parts
- misha
- Has thanked: 155 times
- Been thanked: 432 times
They will fit perfectly.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2199 times
Hey Misha, my memory is not so good on this. As I recall the 93-4 cars had different headlights, and I think the strip under the headlights were different. If you are transferring everything over then will these need swapped too?
- misha
He asked about fenders and doors Neil...they are interchangeable.
Headlights,tail lights and front position lights/blinkers are different.
Bumpers are also different.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I actually doubt they will fit. The early headlights are larger and accordingly are the turn signal units (they are definitely larger, I couldn't fit them in my 94-96 cars). Therefore the cutout in the front fenders has to be larger on the pre facelift cars.
I have a few fenders in storage, I can measure the next time I'm there but most certainly they are different.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
Cutouts for turn signals on pre facelift cars are the same as for later cars and they are not the problem because later cars have bigger trims which goes under them to fill the gap for smaller turn signal lights.
Compare a fender from early and later cars and you will see that they are the same...except the side trims which are smaller on early cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
I'll give it a try, Misha.
I just wonder why I couldn't get these '92 turn signal units to fit in the '96.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- misha
Probably because of a carrier/frame which holds headlights,turn signals,radiators and horns.
Openings for them are bigger for early cars since headlights and turn signals are bigger.
You can swap whole front end (headlights,turn signals,bumper)between early and later cars as long as you have matched front carrier/frame for the car.
This:
This:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I have a little dent on front passenger fender and found locally a perfect matched color fender from early car to swap it when i have time.
I also had doubts will it fit...but when you compare it closely...it is the same...minus a narrower trim...which can also be swapped from my fender.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Now I'm glad I pulled all parts off that 92 I parted out 2 yrs ago...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 789 Views
- 2461 Views
Last post by dikidera
- 845 Views
Last post by bubisamongus
- 773 Views
- 4755 Views
Last post by ARD-Lucky
