Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
- Has thanked: 2864 times
- Been thanked: 1332 times
Do those 2000 R rear bumpers trade for a decent amount?
chaosrob
- Year and Model: 1999 v70R
- Has thanked: 37 times
- Been thanked: 15 times
It is
abscate wrote: 03 Aug 2025, 19:35 I ran the Kat with a Bosal cat and a large down pipe, it was pretty awesome for breathing. The stock Awd is two mufflers, single exit. I though the R was the same?
chaosrob
I don’t believe there is any difference in the rear bumper from the 99 to 2000, just the 2000 actually makes use of the left exhaust cutout. I don’t know anything about their value
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
No, they’re identical to the rest of the AWD rear bumpers, they just have a special (separate) trim piece (like the one in the right for the rest of the AWD cars) and no blanking plate on the left.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- Has thanked: 1611 times
- Been thanked: 4075 times
Rob, that’s a real gem. Take this with a grain of salt, and don’t think you are sitting on a gold mine, but that’s a rare combo…
If you had a stick…..
chaosrob
Well I can almost guarantee that I will have more money in it than it is worth as I am a bit odd about everything and replace a lot of stuff even before it fails. With this sitting in a field for over 13 years that is a lot of parts. I just wanted a fun challenge and to see if I could bring it back, self gratification is the only reward I am looking for.
After firing it up the other day I am getting transmission codes, hopefully this is just me needing to clean the pnp, if it is the actual trans that is bad then it will be a manual. I plan on getting it back on all 4 wheels sometime today and see if it will actually engage in gear and will scan the codes to have some answers hopefully.
abscate wrote: 05 Aug 2025, 04:17 Rob, that’s a real gem. Take this with a grain of salt, and don’t think you are sitting on a gold mine, but that’s a rare combo…
If you had a stick…..![]()
One thing about 1999-2000 (and P2 as well)
Battery Bus voltage is critical. Many hours have been lost firing the parts cannon at codes, only to find weak battery, bad grounds, corroded internally postive cables ('But they look fine on the outside") etc.
The only test for wiring is a good DVM and probing voltages at component pins. referencing to B- or the Supply -
"But it cranks and starts fine" - the battle cry of a failed test.
chaosrob
Never underestimate the importance of solid grounds. Good info, thanks
abscate wrote: 05 Aug 2025, 06:07 One thing about 1999-2000 (and P2 as well)
- V50M66
Yeah, definitely check all the grounds and make sure you have a good battery. If it didn’t before, you might still have stored ghost codes
I’d highly suggest picking up a copy of VIDA on a VM (volvodiag.com) and a DiCE unit - it’s the factory Volvo scan tool and will tell you far more info than any any other scan tool, even expensive professional ones
chaosrob
can anyone confirm that the rear driveshaft bolts to diff torque spec is 26 ft lbs then 90 degree turn? Are these bolts reusable or one time use? Red loctite or just torque?
