aircon fix with cable ties on newer models
T4murvi
Year and Model: V70 2013 D4
Post by T4murvi »
I've got a 2013 D4 V70. The air con compressor clutch is much harder to access than on the older mk 2 model I had before.
Now I've finally reached it the springs are different - not the round cloverleaf type but straight ones.
Can you still do the cable tie fix ? and where do you put the ties please?
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
On the cloverleaf type you’d put the zip tie under it to add some tension to the clutch—but without too much to drag when not engaged.
08 C702.5T (sold)
The non-Swedes:
