Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
chaosrob
Year and Model: 1999 v70R
Has thanked: 37 times
Been thanked: 15 times
Post by chaosrob »
Quick wipe down and vacuum of the interior. Not as bad as I thought although from the seat fabric it looks like the po owned a pet raccoon, or one made it its home when it was in the field
chaosrob
Post by chaosrob »
could you kindly point me to this crossover so I can order it before I start the job? Much appreciated
V50M66 wrote: 06 Aug 2025, 09:31
chaosrob wrote: 06 Aug 2025, 09:09 TY. These are the parts I already ordered. Some have made it here and some will be here this week. I think I pretty much followed your recommendation except maybe the upgrade jkit
That list is looking solid for the most part. I’m wary of that aftermarket unbranded VVT hub seal.
Also, you’re going to want the big crossover pipe for the PCV, and many crush washers for the banjo bolt (2 you actually need, and an extra few for the ones you inevitably drop haha). The vacuum hose on it always snaps upon removal no matter how gentle you are, and they clog up with junk over time. You can replace that big crossover with the Vast catch can instead if you desire
Has thanked: 1611 times
Been thanked: 4075 times
HVAC control valve ???
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
chaosrob wrote: 06 Aug 2025, 12:39 Quick wipe down and vacuum of the interior. Not as bad as I thought although from the seat fabric it looks like the po owned a pet raccoon, or one made it its home when it was in the field
Looks fantastic! Cleaned up nice given how long it was sitting.
chaosrob wrote: 06 Aug 2025, 12:57 could you kindly point me to this crossover so I can order it before I start the job? Much appreciated
Gates makes the Genuine crossover and is well over $100 cheaper for effectively the exact same part, so here’s the Gates numbers. You can get them on RockAuto for $140-160 depending on variant. Feel free to choose whichever variant you want - they’re all compatible with each other, but the late version flows better than the earlier ones.
EMH074 (early)
EMH075 (mid)
EMH078 (late)
As an alternative, you can delete the coolant crossover pipe, block off the coolant ports, and install the Vast catch can, which flows much better than any factory crossover and allows you to get rid of the coolant section, allow for far easier intake manifold removal in the future, and delete the PTC element.
https://vasttuning.com/product/p80-catch-can-kit/
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
V50M66
Post by V50M66 »
abscate wrote: 06 Aug 2025, 13:28 HVAC control valve ???
What FCP calls the firewall heater hose junction for some reason. I was confused by that as well, until I punched the PN into FCP
chaosrob
Post by chaosrob »
Didn't get much done today, I peeled the auto zone cover off the steering wheel, was a bit of a chore as it was baked onto it pretty well. Surprisingly wasn't damaged underneath. Washed it really well and I guess I will see if it gets sticky.
I ran the codes as well and it came back with a P0751 andP0733 for the trans and of course 02 sensors since there are not any. I cleared the codes and fired it up and driveway tested it, the trans codes didn't pop back on but not sure how long you have to drive it for them to pop if there is an issue. When I originally started the car it had the console and ob2 port disconnected and removed, not sure if that will throw any codes with the trans or not.
Tested the heated seats and the ac, both work. The ac was a huge surprise
Working AC required in MO!
Think about putting a wood interior into that, rob. The charcoal leather really looks nice warmed up…even better with a 5 speed swizzle stick and four pedals
chaosrob
Post by chaosrob »
TY. I actually prefer the current trim to wood, wood looks good in estate wagons and fancier trims imho but sportier ones it looks a bit out of place to my eye
abscate wrote: 08 Aug 2025, 04:20 Working AC required in MO!
V50M66
Post by V50M66 »
Nice! Working AC is shocking given how common AC issues are on these. Of the 4 I’ve owned, not one has had working AC when I bought it.
At least one of those trans codes usually comes back immediately. Drive it for a bit and see what happens, but it’s pretty likely you’re in the clear. The 4 speed in these is super robust.
I have both sets of trim (green ‘98 has walnut in a tan interior, blue ‘98 has R metal mesh w/ the R black leather/suede), and wouldn’t change either. The metal w/ black is definitely better for a sportier feel. The wood is classier, especially w/ tan.
Gotta find a set of Karelian Birch or Black Marble if you want something super cool/rare that stands out.
I think I have a set of the metal mesh from my 1999 off if one you cool sport kids would like it. Free to a good home.
