850 1995 Wagon Topic is solved
manovlov
Has thanked: 620 times
Been thanked: 143 times
850 1995 Wagon
Post by manovlov »
Hy Guys,
i hope everyone is fine. Since a long time i didn't visit MVS...
I have a question. Recently, i've lost one rear brake bulb (i mean the bulb stopped to work). On the same time, i've also lost the four dashboard counters bulbs (speedometers, rmp counter, petrol gauje...).
I've tested all the fuse with my metrix, they are all good. I've replaced the bad bulb too.
Does this issu inspire someone ? Could it be possible to lose all these bulb with the rer bulb short cut ?
The thing i didn't do for the moment is to open the dashboard cover and to extract the main "bloc" to test all thes four bulbs.
Should i look around somewhere else before doing this ?
As always, thanks to those who will give me their mind about this issu.
Manov.
Combiné instruments.png (401.13 KiB) Viewed 355 times
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
I doubt that issue is related, unless your alternator "spikes". I would start with testing voltage on idle, then on 3500rpm, then on idle with "demand"(high beams, fan full speeed), heated seats, defroster). If your voltage is in speck, I would move to testing dashboard.(your rear bulb is operational since replacement, so no need to go there). I would take a low amp light tester(or small turn signal bulb) and check of you have supply to the bulbs. If not, check what is missing-commom ground fro. 23/301 vs feed from light switch 4/4.
manovlov
Post by manovlov »
Thanks Vova585.
i do not like to do not know... I've found the guitly part : the rheostat.
That's an efficient forum : make users to use their brain... :D
Part replaced. Of course.
Manov
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
what on god's green earth is a rheostat?
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Vova585
Post by Vova585 »
Manovlov referring to-Light switch assembly with built
in brightness adjuster(rheostat)
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
Rheostat = manual controlled variable resistant device
