Source for gasket between halves of thermostat housing?
jrschwit
Year and Model: '01 V70 T5, '02 V70
Has thanked: 12 times
Been thanked: 8 times
Post by jrschwit »
Subject line says it all. FCPEuro and IPD inform that this gasket is not available separately. Any one know a source? My searching has been fruitless.
For an 02 V70 2.4T. Mine has been leaking for a while and just became so bad I cannot ignore it. I removed both halves from the car and it is definitely the intermediate gasket. Of course I can make one but given the narrow casting where the gasket seals, I don't trust homemade.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
jrschwit wrote: 18 Aug 2025, 14:23 Subject line says it all. FCPEuro and IPD inform that this gasket is not available separately. Any one know a source? My searching has been fruitless.
like this ? , its metal.
This is used but didn't leak, maybe you can apply a bit of high temp sealant. You can have it if you want, or try the boneyard.
2004 v70 2.5 turbo.
Been thanked: 4071 times
Pull a part number and try Skandix.de
Been thanked: 504 times
Post by cn90 »
Somewhat related, if you can't find the gasket...
And since Wahler brand is expensive at $95-$100, an alternative is Facet brand (made in Italy) assembly, about $55-$60 on eBay etc.
I installed the Facet Tstat assembly in my 2006 S60 2 yrs ago (in 2023). It has been flawless.
PS: I have some Tstat assembly lying around (replaced preventively)...I can check when I have time.
jonesg
Post by jonesg »
I replaced mine with this $26 cheapo, my thermostat was kaput.
This cheap version works great except the sensor was no good so I installed the old volvo one.
https://www.amazon.com/Premium-Thermost ... 165&sr=8-2
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Jrschwit, were you able to remove the old gasket in one piece? If so, lay it on a sheet of new gasket material and lightly spray over it with some spray paint which will leave a ghost image on the new material. Cut out the new gasket with an exacto knife, starting with the interior cut first. Then do the exterior cut and the bolt holes. Depending on the bolt hole diameter you may be able to use a paper punch.
I’ve made many a gaskets this way.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
+1 on Facet, been running Facet on my car for almost 10 years.
04s60 2.4
04xc70 2.5t
Post by cn90 »
To make paper gasket, there is a YouTube video by @DavesAutoCenterCenterville...
Very nice trick using ball peen hammer.
Post by cn90 »
br0dy519
Post by br0dy519 »
Thanks JennAI
04s60 2.4
04xc70 2.5t
